Coolant Overflow Line/Reservoir - JeepForum.com
 12Likes
post #1 of 34 Old 10-22-2021, 11:08 AM Thread Starter
jeffmcelwee
1975 CJ5
I finally got my 75 304 CJ5 finished and have started driving it more and more. After the longest ride get I noticed it was purging quite a bit of coolant, and tracing it down I realized the overflow line isn’t connected to a reservoir, it just sits between the grill and the radiator.
I’m assuming there’s supposed to be a reservoir somewhere, or if not is that hose supposed to be attached somewhere? I can’t imagine it’s supposed drain like that.
The only thing that did make me happy was knowing coolant is circulating! Trying to take some positive out of it.
jeffmcelwee is offline
post #2 of 34 Old 10-22-2021, 11:12 AM Thread Starter
jeffmcelwee
1975 CJ5
The heater code is bypassed, not sure if that info makes a difference in this case.
post #3 of 34 Old 10-22-2021, 11:26 AM
LJameson
LJameson's Avatar
AFAIK, my 76 did not come with a reservoir from the factory. At some point in its life, somebody added an aftermarket reservoir that mounted underneath the battery. But everything I read in the 76 Factory Service Manual for mine does not say anything about a reservoir, and the radiator just spews out when the radiator cap pops open.
1976 CJ7 Restoration:
LJameson is offline
post #4 of 34 Old 10-22-2021, 11:35 AM Thread Starter
jeffmcelwee
1975 CJ5
Awesome thanks for the info! I’m still relatively new to the CJ game so is this overflow something I should be concerned about? I’ll def be watching my coolant levels.
post #5 of 34 Old 10-22-2021, 11:40 AM
Lockman75
Junior Member
Lockman75's Avatar
1975 CJ5
This is what I did to my ' 75 :
I was Schooled as a Mechanic 45 years ago. Then I became a Locksmith....... Who Knew ???
Lockman75 is offline
post #6 of 34 Old 10-22-2021, 11:48 AM Thread Starter
jeffmcelwee
1975 CJ5
Awesome! I was looking at overflow canisters on Quadratec, does that just bolt right on?
post #7 of 34 Old 10-22-2021, 01:06 PM
Fourtrail
1974 CJ6
Fourtrail is offline
post #8 of 34 Old 10-22-2021, 01:27 PM Thread Starter
jeffmcelwee
1975 CJ5
Yes, yes I do.
post #9 of 34 Old 10-22-2021, 02:09 PM
Fourtrail
1974 CJ6
Originally Posted by jeffmcelwee View Post
Yes, yes I do.
They are made by a member here, Dadamsnv. A good product from a good guy.
80 CJ-5, 74 CJ-6, 56 CJ-5
post #10 of 34 Old 10-23-2021, 04:54 AM
ECJ-7
1976 CJ7
Something no-one has mentioned, when you add an overflow bottle you also need the radiator cap from a year that came with a bottle. the cap that originally came with your jeep doesn't have the extra gasket that allows the coolant to be sucked back into the cooling system when it cools.
John Strenk and Sparkybob like this.
ECJ-7 is offline
post #11 of 34 Old 10-23-2021, 08:29 AM
bob4703
1974 CJ5
Are you trying to keep the radiator cooling system level at full? It should be about an inch from the top of the tubes. If you let your Jeep find this level and leave it be you don't need a overflow bottle. It will burp until until it does.
Your 75 model isn't 1975 technology.
Paved roads are prime examples of government over spending!
bob4703 is online now
post #12 of 34 Old 10-23-2021, 01:59 PM Thread Starter
jeffmcelwee
1975 CJ5
I drove it around again this morning and it overflowed pretty significantly from the overflow hose...and it was in the 50's so it definitely shouldn't have gotten that hot. I'm thinking the thermostat is bad so I went ahead and ordered new hoses, t stat and housing, water pump and temp sensor. I was thinking maybe the guy before me overfilled it when he replaced the t stat but it feels like a faulty t stat to me. Went with a 180 degree so I'm hoping this at least helps the issue.
post #13 of 34 Old 10-23-2021, 07:37 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
See post 2 in this link!
https://www.jeepforum.com/forum/f8/a...-leak-4429799/
-----JEEPFELLER
JEEPFELLER is offline
post #14 of 34 Old 10-23-2021, 08:44 PM Thread Starter
jeffmcelwee
1975 CJ5
Post 2 is speaking my language! I was starting to be convinced I blew a head gasket (temp gauge isn’t working) but the coolant was filled to the tippy top of the radiator. Going to swap out the water pump and such because they’re all most likely original.
https://www.jeepforum.com/forum/f8/an...-leak-4429799/
-----JEEPFELLER
post #15 of 34 Old 10-24-2021, 07:16 AM Thread Starter
jeffmcelwee
1975 CJ5
Update- after everyone’s help and some digging I saw that it’s a 14.5 quart system. I added water to bring it back to the level it had previously been to and it was exactly 1.5 quarts so the last owner almost certainly filled it with 4 gallons of coolant. I feel way better.
