Con Ferr skid plate - JeepForum.com
 6Likes
post #1 of 21 Old 02-05-2010, 09:05 AM Thread Starter
ErikEastman
Con Ferr skid plate
Con Ferr used to make a bad *** front end skid plate for Cj's. I can't seem to find one anywhere.
They cover from spring to spring and also protect the power steering. I think they attach to the front bumper or frame ends, and in the rear they hang from brackets that attach to the frame somewhere around the shock mounts.
I think Con Ferr is out of business or something, if anyone knows what skid plate I'm talking about, is there a similar product?
ETA here's a pic I found:
ErikEastman is offline
post #2 of 21 Old 02-05-2010, 10:07 AM
CSP
ConFerr has been gone for several years now.
Can't say that I would ever want or need that under my CJ. My springs and axle tubes are the only things that I drag over rocks. The steering box is pretty well protected via the leaf springs unlike a TJ that has nothing in its way.
CSP is offline
post #3 of 21 Old 02-05-2010, 02:58 PM Thread Starter
ErikEastman
CSP, not sure if you can see it, but there is a small radiator for the transmission cooling system mounted behind there.
While I appreciate that you would never want or need one, telling me this and all your reasons why does nothing to help me find one.
post #4 of 21 Old 02-05-2010, 03:07 PM
Military Jeeper
Military Jeeper's Avatar
1979 CJ5
That was funny....I'm just saying
Jason "MJ" - 79 CJ-5 | SOA/HI-STEER | 304/T18A/D20 w/3:1 TeraLow | Holley Avenger Carb | Edelbrock Performer Intake Manifold | DUI Distributor | K&N Filter | Centerforce 2 Clutch | Waggy D44's | 4.11's | ARB's | Hydroboost | HAD Shafts | 35 Toyo MT's|
Military Jeeper is offline
post #5 of 21 Old 02-05-2010, 03:28 PM
CSP
Welcome to the internet.
Like I said, ConFerr is out of business in reference to your statement that
It doesn't hurt you that I added my opinion.
CSP is offline
post #6 of 21 Old 02-05-2010, 03:43 PM
Military Jeeper
1979 CJ5
That was funny too............
I think his question is answered though now. ConFerr was huge about 10 yrs ago, I remember buying shackles from them.
BREAK
ErikEastman,
I believe Kilby Enterprises makes a CJ Steering Skid but I don't know of anyone who makes an engine skid for a CJ. Just not a lot of demand for CJ's especially when TJ's have ruled the market for the last 10 yrs and JK's are the new thing to own.
post #7 of 21 Old 02-05-2010, 05:36 PM Thread Starter
ErikEastman
Apparently my sarcasm didn't translate regarding conferr.
Anyway, I know I can't get one from conferr, I was hoping someone else made one like it, or someone knew where I might find a used one, and that someone could perhaps direct me to it.
Regardless of yours or anyone's opinion of them, I happen to have a need for it. So if you don't know where I can find one, please take your mastery of the internets to someone else's thread.
Thanks
post #8 of 21 Old 02-05-2010, 05:38 PM Thread Starter
ErikEastman
BREAK
ErikEastman,
Thank you. It's looking like I may be fabricating what I need.
post #9 of 21 Old 03-21-2020, 03:54 PM
akula
Found one!
I know it is despicable to necrothread but because of this thread I actually found one.
Was looking through Craigslist ads and found one listed in Ohio. Would have never have known about it except for the OPs picture link so I recognized it mixed in with various bumpers in the ad photo.
Got it for 30 bucks plus shipping. But I am not so sure it is a Con-Ferr product.
The other Con-Ferr stuff I have (rack and shackles) are stamped Con-Ferr. This plate and the 2 mounting legs are not marked at all.
Maybe it shipped with a sticker instead but since I have only seen one photo and the one I actually own who knows.
The 2 legs mount with a single bolt to the bottom of the frame using the hole fwd of the sway bar mount. On the passenger side this is easy as the hole is unused but has a threaded nutsert in it. On the driver side that hole is one of 3 used to mount the steering box mounting plates and would not come out. In the end the nutsert tore out of the hole rather than let go of the bolt. I just threaded in a bolt the same size as the hole and called it a day. Other end of the legs have 2 holes each to bolt to the plate.
The plate does cover well and can also bolt through the face of the bumper.
Usefulness is debatable but I like finding vintage parts. Found a pair of Go Rhino trusses/ axle skids on Craigslist in NJ. Sometimes you just get lucky and find stuff.
Thanks to the OP for posting the picture. It helped me.
akula is offline
post #10 of 21 Old 03-22-2020, 05:18 PM
Jim1611
Jim1611's Avatar
You should post a picture as I see none on his post.
Cutlass327 likes this.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #11 of 21 Old 03-23-2020, 03:47 PM
akula
Here it is.
turbogus and Jim1611 like this.
akula is offline
post #12 of 21 Old 03-23-2020, 06:44 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
That'd be interesting to see once installed.
Rick
Cutlass327 is offline
post #13 of 21 Old 03-24-2020, 04:11 PM
akula
This was the original photo in the thread
turbogus, Cutlass327 and Jim1611 like this.
akula is offline
post #14 of 21 Old 03-24-2020, 07:37 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
That looks nice! I would be nervous with the cooler that low, a stick at the wrong angle would not end well...
Rick
post #15 of 21 Old 03-25-2020, 11:28 AM
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
Here it is.
Did you sandblast and powdercoat it before installing?
OrangeCJ-5 is offline
Skid plate shims Mike1084 Jeep CJ Forum 6 10-05-2009 12:29 PM
Skid Plate From A Xj Fit On A Cj sdozzi Jeep CJ Forum 1 02-23-2009 04:25 PM
Skid Plate philipbeacon Jeep CJ Forum 4 04-25-2005 07:03 PM
cj5 skid plate help Yellow91YJ Jeep CJ Forum 1 11-18-2004 04:35 PM
gas tank skid plate 77'cj7 Jeep CJ Forum 0 06-30-2004 11:01 PM
