clutch replacement - JeepForum.com
post #1 of 6 Old 08-01-2020, 11:30 AM Thread Starter
jeepdaddy65
1972 CJ5
clutch replacement
I have a 72 CJ5 with original 304 V8 a T15 transmission and a dana 20 transfer case.. looking to replace the clutch. The problem is, multiple size clutch kits are listed, from 10 3/8 to 11 inch. Anyone know what size I should get. Would like to have parts before I do the job to minimize down time as I drive it a lot in the good weather. Thanks in advance
jeepdaddy65 is offline
post #2 of 6 Old 08-01-2020, 01:46 PM
oldschool74cj5
hello
looking at rockauto all the 3 finger pressure plate were 11 inch and the diaphragm were the 10.5. my thinking is that the size more depended on what type of pressure plate. my personal preference is the diaphragm type.
oldschool
oldschool74cj5 is offline
post #3 of 6 Old 08-01-2020, 02:55 PM
hp_lovecraft
1981 CJ5
Weird, I was just looking at the exact same thing. I bought the cheap $62 one.
Last time I changed the clutch was 12 years ago, and had the throwout bearing fail on me a few days ago. The drive home was no fun.
Its not a technically hard job, and doesnt require special tools. Just annoying, heavy, awkward parts.
hp_lovecraft is offline
post #4 of 6 Old 08-01-2020, 11:12 PM Thread Starter
jeepdaddy65
1972 CJ5
Thanks for the info. So it should not matter if it's 10 3/8 or 11 inch ?
post #5 of 6 Old 08-02-2020, 12:35 AM
RedNeckCorvette
1979 CJ7
I think you should ask the question what brand of clutch most people use and have had the best success with in there jeeps.
I would say a new LUK kit was first on my list, because they have proven to be the best with the lowest fail rate, I even have one in my dump truck and so far have never spun it.
RN
RedNeckCorvette is offline
post #6 of 6 Old 08-03-2020, 11:16 AM
Nor Cal CJ5
Nor Cal CJ5's Avatar
You need to make sure the flywheel will accept what ever clutch you are wanting to use. Pull the old and match it up.
10.5" pressure plate (3 finger) and a 10-3/8" clutch is what I have stock/original. But don't rely on what I have - 1972 was a weird year for the 304...
1972 CJ5 304 V8, 3 speed manual trans
Nor Cal CJ5 is offline
