Clutch problem - JeepForum.com
 1Likes
  • 1 Post By pedal2themetai
post #1 of 5 Old 08-25-2019, 05:58 AM Thread Starter
Lordhau
Clutch problem
Hey! I bought a jeep cj7 and when I push the clutch all the way in it gets stuck and it takes a while before it sets speed and comes out. I just wonder what the problem can be?
Lordhau is offline
post #2 of 5 Old 08-25-2019, 09:10 AM
only in a jeep cj
Could be several things. While uncommon, maybe the throw out bearing is sticking on the collar it rides on
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 5 Old 08-25-2019, 10:02 AM
pedal2themetai
1956 CJ5
HI, the speed of the clutch has nothing to do with it coming back out. it is spring operated. if your pedal does not come back to the top when letting out its a spring or adjustment issue.. if the motor revs but Jeep does NOT pick up speed then the clutch and pressure plate are bad.. if you hear a squealing when operating the clutch its the throw out barren (bearing, beering ect.).
good luck
tim
trailhead2004 likes this.
pedal2themetai is offline
post #4 of 5 Old 08-25-2019, 10:35 PM
ThisGuyUKnow
good luck
tim
Thanks pedal2thametai! Good info!
1985 CJ7 Laredo, 4.0, NV3550, D300, 3.31 AMC 20 w/trac loc
ThisGuyUKnow is offline
post #5 of 5 Old 08-26-2019, 01:20 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Clutch cover plate.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is online now
