clutch pivot arm - JeepForum.com
 9Likes
post #1 of 31 Old 10-06-2021, 01:23 PM Thread Starter
MikeB82
1982 CJ7
clutch pivot arm
how much grease is needed inside the clutch pivot arm after cleaning and relacing the boots?
MikeB82 is offline
post #2 of 31 Old 10-06-2021, 01:28 PM
Fourtrail
1974 CJ6
I would fill from the zerk on the shaft until you see the boots just start to balloon out showing that you have the tube and pivots full of grease.
JEEPFELLER and Techlight like this.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #3 of 31 Old 10-06-2021, 05:22 PM Thread Starter
MikeB82
1982 CJ7
WOW! this is an education working on CJ's. Thanks, Mike
MikeB82 is offline
post #4 of 31 Old 10-06-2021, 06:58 PM
JERSEYJOE
JERSEYJOE's Avatar
Clutch
Mike is there a source for replacement boots?
SPEED COSTS MONEY: HOW FAST DO YOU WANT TO GO?
JERSEYJOE is offline
post #5 of 31 Old 10-06-2021, 09:18 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
JEEPFELLER is offline
post #6 of 31 Old 10-07-2021, 12:09 PM
bob4703
1974 CJ5
The rubber in the Crown boots are much better now. Mine have been on for two years and show no sign of weather cracking.
Paved roads are prime examples of government over spending!
Last edited by bob4703; 10-15-2021 at 08:20 AM. Reason: I left out a key word "no!"
bob4703 is offline
post #7 of 31 Old 10-14-2021, 08:34 PM Thread Starter
MikeB82
1982 CJ7
just checking back in and I had purchased the Crown rebuild kit and it appears to be great and finished today putting all back together BUT, now I checked my pics of when I took it off and can see where it bolts to firewall but where does the other end attach? I didnt take as good a pic as I thought and after replacing the engine i am not sure where to mount the other end of the pivot, duh! any pic would be appreciated or just plain english. Thanks Mike
MikeB82 is offline
post #8 of 31 Old 10-14-2021, 08:49 PM
Fourtrail
1974 CJ6
It bolts to the face of the bellhousing.
post #9 of 31 Old 10-15-2021, 07:44 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
My stuff needed a good cleaning when I too k my pic.
Fourtrail has got to be a good housewife with his being that clean.
I posted my pic to show the position of the grease fitting.
You can mistakenly "Flip" the bell crank (Yes, it will wrongly fit!) and now the "longer arm" is not connecting with the clutch pedal rod.
It's now harder to push the pedal, you have lost mechanical advantage.
Moral of my story---in the relaxed position---the grease fitting points downward
-----JEEPFELLER
post #10 of 31 Old 10-15-2021, 08:37 PM Thread Starter
MikeB82
1982 CJ7
thanks to Fourtrail and Jeepfeller for the info and pics. Very helpful for an old man doing his first jeep restore. Thank again, Mike
MikeB82 is offline
post #11 of 31 Old 10-16-2021, 08:29 AM Thread Starter
MikeB82
1982 CJ7
here I am again and thanks again for both your pics cause after trying to install the pivot I realize that I am missing the adjuster assembly. It was never there. My son bought the Jeep sight unseen and we knew it had a blown engine so when delivered it was pushed into the shop and not familiar with Jeeps when taking it apart I didnt catch that it was missing the adjuster. But your pics both show it so I assume I should have one also. As the famous philosopher Roseann Roseannadana said "its always something"
MikeB82 is offline
post #12 of 31 Old 10-18-2021, 06:53 AM
keith460
keith460's Avatar
There's also a rubber slip on bumper, or snubber, at the end of the Adjuster to eliminate rub through or noise as you engage the clutch fork in and out. Not many people know its suppose to be there.
1984 CJ-7 Renegade
keith460 is online now
post #13 of 31 Old 10-18-2021, 07:02 AM
JERSEYJOE
JERSEYJOE's Avatar
Clutch rod
Nice. I used the plastic ice cream cone shaped point that comes on the AMX's set up
post #14 of 31 Old 10-18-2021, 07:53 AM
STJP
STJP's Avatar
Attachment 4013315
Keith,
Is there a source for the snubber?
JS
STJP is offline
post #15 of 31 Old 10-18-2021, 08:11 AM
keith460
keith460's Avatar
clutch pivot arm
Yes, a short piece of rubber vacuum hose cut to length.
The steel tip of the Adjuster still makes contact with the clutch fork. The snubber just slips over the end of it. A little grease on the ball end enures squeak free operation.
AMC/Jeep actually called it a Seal P/N: J313 0998.
STJP likes this.
1984 CJ-7 Renegade
