clutch leak - JeepForum.com
post #1 of 6 Old 05-23-2015, 02:18 PM Thread Starter
derfer42
clutch leak
hi guys this is my first post i just got my jeep yesterday as a grad gift and when im driving it i cant move the shift so i got out filled up the clutch master cylinder and pumped the clutch and was fine for about 15 mins then i have to do it again when i got home i looked under the jeep and there was a leak at the bottom of the transfer case i need some big help her guys what should i do
derfer42 is offline
post #2 of 6 Old 05-23-2015, 03:02 PM
1997happy
1983 CJ5
Sounds like the clutch slave cylinder has gone south.
1997happy is offline
post #3 of 6 Old 05-23-2015, 03:58 PM
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
X2 on the bad clutch slave cylinder unless you see it leaking out of the master or the line somewhere. The drip should be at the transmission and not the transfer case so that might be another issue.
FYI - This should be posted in the Wrangler forum and not the CJ forum unless it is not the vehicle in your profile.
OrangeCJ-5 is offline
post #4 of 6 Old 05-23-2015, 11:54 PM Thread Starter
derfer42
oops sorry for the miss post guys and yeah it was from the transmission sorry this is my first time
derfer42 is offline
post #5 of 6 Old 05-24-2015, 07:33 AM
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
According to what RockAuto lists, it looks like the slave cylinder is internal. Clean things up as best as you can, refill the system and verify that the slave is leaking unless you can see that is where is it coming from. That should be pretty easy to do if it leaked out as fast as you said it did. With the engine off and brake set/wheels chocked, get someone to pump the clutch pedal while you look for the leak. Since the transmission will have to come out you might want to consider replacing the clutch assembly and the engine rear main seal. Good luck.
P.S. There is a lot of information around here. After looking for a while you will be able to change your profile descriptions from 'stock' to what the part actually is like Dana 30 axle for example.
post #6 of 6 Old 05-24-2015, 01:29 PM Thread Starter
derfer42
okay thank you very much orange
derfer42 is offline
clutch , help needed , leak , transfer case
