Clutch fork plum wore out ? - JeepForum.com
post #1 of 14 Old 08-28-2015, 08:02 AM Thread Starter
Gratefulcaver
1983 CJ7
After a successful T-5 / 435 swap I've discovered another puzzle
The clutch adjustment rod has actually pushed through the back of the clutch fork ... The fork itself is not in bad shape , not rusted or anything?
I'm pretty sure I've adjusted it correctly and using a stock pressure plate ....
Is it possible that it's just wore out ?
I put an acorn nut on the end of the adjustment rod that fit perfect in the fork arm for a quick fix for now ....
Gratefulcaver is offline
post #2 of 14 Old 08-28-2015, 08:19 AM
Pathkiller
1974 CJ5
Yep. Not uncommon at all. The clutch fork gets pretty thin at the cup where the rod sits. Most people usually never grease this area and with time friction leads to a hole.
Pathkiller is offline
post #3 of 14 Old 08-28-2015, 08:21 AM
Mike Romain
Been running an acorn nut on mine for 10 years or more now for the same reason.
Mike
Mike Romain is offline
post #4 of 14 Old 08-28-2015, 08:27 AM
2001WJv8
2015 WK
mine's heading this way ... good to know about the fix - will probably put an acorn on before it finishes the hole
'15 WK2 Diesel 4x4 ORII, Nitto TG2 275/65r18, BORA 1"f/1.25"r spacers, RRO super sliders
2001WJv8 is offline
post #5 of 14 Old 08-28-2015, 08:39 AM Thread Starter
Gratefulcaver
1983 CJ7
Man that's great ! Easy fix ...
Thanks guys for your input
post #6 of 14 Old 08-28-2015, 09:11 AM
Pathkiller
1974 CJ5
I wouldn't consider it a permanent fix, and I would consider it a symptom of other wear. Inspect your clutch linkage thoroughly. It's also not uncommon for the clutch rod to wear through at the point where it connects to the pedal or to the Z-bar. And if this rod breaks while you're driving, you are stuck in gear and it could be very dangerous. If you've got enough wear to wear out a clutch fork, it's highly likely that other parts are worn out too.
post #7 of 14 Old 08-28-2015, 09:23 AM
Mortgage-payer
Mortgage-payer's Avatar
1976 CJ7
Originally Posted by Pathkiller View Post
.... If you've got enough wear to wear out a clutch fork, it's highly likely that other parts are worn out too.
Worth repeating. Clutch actuating rod ends are probably worn through.
I call it a distributor, not a dizzy.
Mortgage-payer is offline
post #8 of 14 Old 08-28-2015, 09:52 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
So, are we talking a white, black, red, or bur acorn?
Wish we had oak trees around here. I don't think a pine cone would work too well.
Matt
Matt1981CJ7 is offline
post #9 of 14 Old 08-28-2015, 10:33 AM
Mike Romain
Matt
Mine is rust brown. :-)
Mike
post #10 of 14 Old 08-29-2015, 08:24 PM
83vert
1982 CJ7
Mines pushed through too but I think I need to check the rest of the pieces as well. Good post
I am in deep
https://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline
post #11 of 14 Old 08-29-2015, 08:51 PM
RedNeckCorvette
1979 CJ7
We had some push rods do the same thing to the rockers on my eldest sons first rig. An old AMC 258 -6 cyl. with about 200k on it.
I welded a gob on the two or three that were in the worst shape and tried to Keep most of the pocket in tact, checked the clearance! and he ran it the whole summer, until a con rod came out the side of the case.
I told him it was a rod knock! with two or three other young bucks in the rig he said no pop it is just the exhaust banging against the transmission. His first year going to mechanics school. Fix it or don't drive, he turned out to be a pretty good wrench
RN
RedNeckCorvette is offline
post #12 of 14 Old 08-30-2015, 08:06 AM
keith460
keith460's Avatar
Most people don't know, but there is suppose to be a small rubber snub that fits over the ball end of the Adjuster Rod. It will cushion the end of the rod where it sits against the Clutch Fork. And a little grease helps as well.
1984 CJ-7 Renegade
keith460 is offline
post #13 of 14 Old 08-31-2015, 07:10 PM
83vert
1982 CJ7
Posted on the wrong thread lol sorry
I am in deep
83vert is offline
post #14 of 14 Old 08-31-2015, 09:06 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
The hydro clutches came with a white plastic cap on the end of the rod. Mine never lasted very long, so I simply rounded the slave cylinder rod and apply grease periodically. I know it's a different set up for the older CJs with bellcrank linkages. I wonder if a rocker arm pivot ball would fit in that pocket. Maybe weld it to the end of the pushrod.. ?
BESRK is offline
