Cj7 v8 - JeepForum.com
 1Likes
  • 1 Post By LumpyGrits
post #1 of 11 Old 06-29-2020, 01:16 AM Thread Starter
Sjtrouble
Sjtrouble's Avatar
Cj7 v8
Howdy y'all,
I have just recently got a hold of a beautiful AMC 304 V8 from a 74 cj5. I am looking to do an engine swap on 84 cj7. My cj7 has the T5 tranny with a full stock 258 Inline 6. Is there anything I should know or be concerned about before I do a swap? (Wiring, spline output, bolting up, transmission strength etc.?)
Thanks,
John
Sjtrouble is offline
post #2 of 11 Old 06-29-2020, 05:10 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
There's a butt-load of info on this swap. Did you search at all?
https://www.jeepforum.com/forum/f8/o...thread-377983/
Matt
Matt1981CJ7 is offline
post #3 of 11 Old 06-29-2020, 05:19 AM
LumpyGrits
That T5 will not last behind the 304.
Find a better tranny.
Gary
JEEPFELLER likes this.
Have'n you along, is like loose'n 2 good men
LumpyGrits is online now
post #4 of 11 Old 06-29-2020, 10:40 AM Thread Starter
Sjtrouble
Sjtrouble's Avatar
Gary
so could I get away with a t4? What would you suggest?
post #5 of 11 Old 06-29-2020, 02:05 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
The aluminum trannys don't seem like they wanted to last in the CJs they came in. (Yeah, y'all can rebuttal that comment too!)
A CJ 3 or 4 speed with the case composed of cast iron from 1972-1981 would tolerate the added power.
---JEEPFELLER
JEEPFELLER is offline
post #6 of 11 Old 06-30-2020, 07:15 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
They do well with the T176/T177 as stock, or the older truck type boxes. The Peugeot unit and the T4/T5 are no way as strong out of the box, though I am told a T4/T5 is most at risk when offroading as the cases can flex slightly. Plenty here on the Forum who run a V8 with the T4/T5, but if I was spending the time and money I would install a stronger transmission.
That then leaves the question of where you place your new drivetrain and if that will need different length driveshafts. The T176 used the same driveshafts as the T4/T5.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #7 of 11 Old 06-30-2020, 07:47 AM
Matt1981CJ7
1981 CJ7
A T-18 or T-19 (my preference) transmission are almost bomb-proof. With the necessary t-case adapter from Advanced Adapters they will also be almost the identical length of your T-5, so driveshaft lengths would remain the same.
You can get a T-19 in either 4, 5, or 6:1 1st gear ratios, so you can match it it up with your differential gearing to get a true 4-speed. You won't have overdrive, however. Some people think the T-18/19s shift like a dump truck transmission. But with the proper length shifter, I don't find my T-19 shifts any more difficult than the T176, T4-5, or SR4.
Matt
post #8 of 11 Old 06-30-2020, 08:23 AM
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
Something else to consider: Do you have emissions testing?
OrangeCJ-5 is offline
post #9 of 11 Old 06-30-2020, 10:11 AM
Axhammer
Axhammer's Avatar
Thatís what I thought when I saw a 1974 engine going in a 1984 Jeep. But, AMC didnít use casting numbers on blocks & heads to differentiate the different years the V-8ís were being manufactured. Given that bit of info you might get away with it in a state that checks emissions as long as you install the emission components that they look for. If you are in a non emissions state, then itís all moot.
The guy I take my cars to for inspection said as long as my 1985 CJ-7 has an O2 sensor and a catalytic converter, he will pass it.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is online now
post #10 of 11 Old 06-30-2020, 07:57 PM
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
There was no V8 option for a CJ in 1984. If the state doesnít care then it is indeed moot.
post #11 of 11 Old 07-01-2020, 06:37 AM
Axhammer
Axhammer's Avatar
Good point, something I missed. I guess it comes down to what the state allows.
