CJ7 Transmission Noise - JeepForum.com
post #1 of 12 Old 11-26-2019, 12:47 PM Thread Starter
calebcj7
1977 CJ7
Cj CJ7 Transmission Noise
Hey guys, had great luck on the forum before so figured id try it again.
Just finished putting a 304 into my cj7 and took it out for a test drive. I heard a grinding sort of noise in the transmission when it was moving even coasting in neutral. I took it back after only about a tenth of a mile because i didn't want to do any damage.
Maybe low on fluid? I cant imagine that because i didnt really touch the transmission, I left it in when i did the swap.
My friend heard the same sort of noise except it was constant and not only when the jeep was moving, after he put pulled his 360, and it was the pilot bushing, and the noise went away after some driving.
Any thoughts, maybe the T-Case?
Thanks!
calebcj7 is offline
post #2 of 12 Old 11-27-2019, 06:20 AM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
Can you raise the CJ on jack stands, put in gear and listen for the noise: bell housing, transmission, or transfer case?
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is online now
post #3 of 12 Old 11-27-2019, 07:27 AM
Fourtrail
1974 CJ6
Did the noise change with road speed or with engine speed?
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #4 of 12 Old 11-27-2019, 10:42 AM Thread Starter
calebcj7
1977 CJ7
With road speed, any movement at all even just coasting.
I was breaking in the engine in my garage and didnt hear anything.
calebcj7 is offline
post #5 of 12 Old 11-27-2019, 10:43 AM Thread Starter
calebcj7
1977 CJ7
With it running and in gear i assume?
calebcj7 is offline
post #6 of 12 Old 11-27-2019, 12:16 PM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
Yes. I would be good to have a helper. Someone to sit in the driver's seat and the other to listen to the noise.
Tim
post #7 of 12 Old 11-27-2019, 12:31 PM
Fourtrail
1974 CJ6
This should rule out the flexplate/torque convertor. did you only shift the trans to neutral, or did you also shift the t-case into neutral?
Did you pull the entire driveline during the swap, or only the motor?
post #8 of 12 Old 11-27-2019, 01:15 PM Thread Starter
calebcj7
1977 CJ7
Since its a manual it shouldn't even have a flex plate or torque converter anyway right? I only shifted the t case to 4 and 2 hi not neutral.
I only pulled the engine so thats why im confused, i never even touched the trans.
On a side note, just drained the transmission oil and it was very thick and milkshake color and only had about 1 qt instead of the 1.4 qt it should have so maybe that could be it when i fill it back up? Also the boot where the clutch linkage connects to the tranny is ripped to shreds and leaving the tranny open so maybe water got in that way?
calebcj7 is offline
post #9 of 12 Old 11-27-2019, 02:24 PM
Fourtrail
1974 CJ6
Oops, not sure where I got the auto. Yeah, no flexplate/torque convertor. There is a seal at the front input, so a bad clutch fork boot won't let water into the case.
post #10 of 12 Old 11-27-2019, 02:59 PM
TerryHowe
TerryHowe's Avatar
1949 CJ3A
If you have the noise coasting, was the noise associated with engine rpms or speed? Like if you drove in first gear to 3000 rpms, pressed in the clutch and put the trans in neutral and let the engine idle the sound should be different speed vs rpm. I would do this before getting it on jack stands.
I would assume the noise is a clutch issue more than transmission .
Do you have the 3 speed or 4 speed. I don't think it matters much, but might help.
Terry Howe
'49 Willys CJ-3A
TerryHowe is online now
post #11 of 12 Old 11-27-2019, 04:16 PM Thread Starter
calebcj7
1977 CJ7
It was associated with speed, rpms had nothing to do with it.
I have a 3 speed the t150
calebcj7 is offline
post #12 of 12 Old 11-30-2019, 12:20 PM Thread Starter
calebcj7
1977 CJ7
Thankyou to everyone for your adice, the noise went away for me after new fluid was put in!
calebcj7 is offline
304 , cj7 , grind , jeep , transmission
