CJ7 Steering Linkage - JeepForum.com
post #1 of 5 Old 09-14-2018, 11:17 AM Thread Starter
DougE
1983 CJ7
I just researched this for a friend and thought I might as well share.
CJ7 Steering Linkage (Wide Track)
JEEP / MOOG
3 Tie Rod End J8134350/ DS1070
4 Tie Rod Tube J3200671/ ES2004S
5 Tie Rod End J0921317/ ES140R
15 Tie Rod End J0920535/ ES62L
17 Tie Rod Tube J8134290/ N/A (43.84”)
18 Tie Rod End J0921317/ ES140R
1983 CJ7, 258I6, T4, Dana 300, 31x10.5x15 DuraTrac
DougE is offline
post #2 of 5 Old 09-14-2018, 11:37 AM
STJP
You da man!
Thanks,
STJP
STJP is offline
post #3 of 5 Old 09-14-2018, 01:22 PM
Fourtrail
1974 CJ6
You should specify if that is narrow trac or wide trac as part #3 and #17 will be different lengths/part numbers.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #4 of 5 Old 09-14-2018, 09:54 PM
shaneB
It says wide trac
It's the same diagram you can see at the local auto parts store while you are buying the parts.
shaneB is offline
post #5 of 5 Old 09-15-2018, 01:28 PM
only in a jeep cj
So here’s a question.
You see 5 and 18 are the same.
I would love it if 15 and 3 were the same and the drag link was a turntable tube with a regular tie rod end.
I see the heavy duty versions are like this.
So.... are the stock ones (part 3) solid because it operates at changing angles and needs to be stronger vs the tie rod tube behind it that pushes or pulls in a straight line?
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
