CJ7 replaced radiator - now it runs hotter? - JeepForum.com
 24Likes
post #1 of 33 Old 07-12-2020, 04:58 PM Thread Starter
mhobson3
Hello everyone - hope you all are doing well!
I recently purchased a 1983 CJ7 258. I knew it had a pinhole radiator leak, so I put some Bar's Stop-Leak in it until I could save up a little cash to put a new radiator in it. I actually ended up spending the money to re-core the original radiator (not cheap lol!). Before the radiator replacement, the Jeep ran at the center of the temperature gauge all day long with no problems. I replaced the radiator and I also replaced the thermostat while I was at it. Now that it is all back together, it actually runs hotter on the gauge (somewhere between 2/3 and 3/4 of the way up on the gauge). It's still in the green on the gauge, but that seems abnormal to me with a new radiator and thermostat. Did I do something wrong? What would your advice be?
mhobson3 is offline
post #2 of 33 Old 07-12-2020, 05:32 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What temperature rating thermostat was installed, and what temp is specified ? Did you install a Stant thermostat, or some cheap crappy store brand Chinese thermostat ?
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 33 Old 07-12-2020, 05:34 PM Thread Starter
mhobson3
I put a new Stant 195 in it - 195 was the temp rating of the old thermostat that was in there so I just went with that.
mhobson3 is offline
post #4 of 33 Old 07-12-2020, 05:37 PM
CJ7-Tim
CJ7-Tim's Avatar
So, assuming the Stop-Leak leak stuff isn't buggering up anything, it's fine.
RedNeckCorvette and mhobson3 like this.
- Benjamin Franklin
CJ7-Tim is offline
post #5 of 33 Old 07-12-2020, 05:40 PM Thread Starter
mhobson3
I just figured it would at least run the same temp on the gauge, if not cooler with a new radiator. I'm going to be wheeling in the desert and if it's already hitting 2/3rds of the way up on the gauge at my house where it's 75-80 degrees, I guess I worry when I take it out to where it's 100+ that it's going to have problems.
mhobson3 is offline
post #6 of 33 Old 07-12-2020, 06:12 PM
80cj
80cj's Avatar
1980 CJ5
Do you still have the old thermostat? Maybe you can try reinstalling it and see if your old normal temperature returns. Also, is the new radiator core the same thickess and fin count as the old one
mhobson3 likes this.
80cj is offline
post #7 of 33 Old 07-12-2020, 06:19 PM Thread Starter
mhobson3
The radiator is the same radiator that was in it - I just had it re-cored and then I installed it. The old thermostat looked pretty shot when I pulled it, so I tossed it. It's pretty puzzling to be honest, but maybe I'll just have to get used to it running at it's new "normal" temperature.
mhobson3 is offline
post #8 of 33 Old 07-12-2020, 06:33 PM
jay-h
Is it possible that the recoring job was not well done? (excess solder etc?)
I should note that if you've run through muddy water you may want to flush through the fins with a garden hose. When I did that some hidden mud came out and the hot weather temperature dropped noticeably.
uptillnow and mhobson3 like this.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #9 of 33 Old 07-12-2020, 06:36 PM Thread Starter
mhobson3
I hope not, but it's always possible. How would I even check that?
mhobson3 is offline
post #10 of 33 Old 07-12-2020, 06:47 PM
jay-h
After I posted, I was thinking that same thing, I don't know.
However,I would consider doing a system flush with a reputable cleaner, then flush clear with water (if you have not done this already) then refill. It is possible that the leak fix is reducing your heat transfer.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #11 of 33 Old 07-12-2020, 07:31 PM Thread Starter
mhobson3
I used my garden hose and blasted through the thermostat opening pretty good before I put everything back together. I made sure the water was running clear before I was done. I'm a Jeep N00b so I'm not too sure if that is even an acceptable way of doing it lol.
BTW I appreciate everyone's input - this is really helpful for me!
mhobson3 is offline
post #12 of 33 Old 07-12-2020, 08:40 PM
ccoyle71
An IR thermometer may give you some piece of mind - they aren’t expensive - and its easy to have an idea of the temp at the thermostat. Just an idea.....
https://www.amazon.com/dp/B00837ZGRY..._dI8cFb96BM727
Chrisinchwk and mhobson3 like this.
ccoyle71 is offline
post #13 of 33 Old 07-12-2020, 08:55 PM Thread Starter
mhobson3
Thanks for the advice - what would be an acceptable temperature reading at the thermostat?
mhobson3 is offline
post #14 of 33 Old 07-13-2020, 04:37 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
195F +/- 5 is the coolant temperature, you may see a bit less on an infrared thermometer as you are not directly measuring the coolant.
You should only see the temperature the thermostat is allowing to pass. It should be closing and opening all the time as your cooling system is capable of running cooler than that. the job of the thermostat is to keep coolant IN the engine until it heats up enough. The job of the radiator is to cool it more than enough.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #15 of 33 Old 07-13-2020, 04:51 AM
CJ7-Tim
CJ7-Tim's Avatar
An old thermostat that was weak or stuck open can easily allow the engine temp to run on the low side. "Normal" is about 195*-210*.
- Benjamin Franklin
CJ7-Tim is offline
