Cj7 plastic dash bezel removal - JeepForum.com
post #1 of 8 Old 08-12-2019, 04:47 PM Thread Starter
Jlipka77
Thanks in advance
Trying to remove these plastic bezel. The metal ones came off easy. The plastic is a different story. Any suggestions? They only have a notch on top side and the notch is fill with the top cover of the bezel.
Jlipka77 is offline
post #2 of 8 Old 08-12-2019, 04:54 PM Thread Starter
Jlipka77
here is a pc of issue
Jlipka77 is offline
post #3 of 8 Old 08-12-2019, 05:05 PM
Hoover7
Hoover7's Avatar
The three vent/air cables come out as a unit (fresh air/heat, defrost, and temp cables). Reach behind the dash and squeeze the two plastic (clips/retainers) together, then the entire cable assembly will pull through the front of the dash panel. It may help to use a small pair of pliers to help depress the retainers together. However, in order to fully remove these, you must first disconnect the other end of each cable from the heater box.
Name:  Vent cables.jpg
Note the two tabs/retainers on the cable to the far right.
Hope this helps,
Hoover
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
post #4 of 8 Old 08-14-2019, 02:07 PM Thread Starter
Jlipka77
got it. thank you
Jlipka77 is offline
post #5 of 8 Old 02-21-2020, 09:27 PM
258
Just broke my AIR cable (second knob down) just by pulling on it. This is the cable that controls the flap inside the hood vent. Where exactly does this cable connect on the heater box?
It's dark outside (in a parking lot), and I can't see anything moving at the box. Feels like this cable broke at the knob shaft (plastic) just behind the dash itself. I wanted to ask up front so I can reach up to see if the actual cable itself broke as well. BTW, the AIR cable never really pulled IN or OUT smoothly. Always seemed to be some tension on the cable line.
Heading home to do more research but maybe someone can chime in to save me some time on where it attaches on the box (lower left bottom corner?). Luckily I have 2 extra sets of cables at home.
258 is online now
post #6 of 8 Old 02-22-2020, 06:46 AM
John Strenk
John Strenk's Avatar
1976 CJ5
You can see it clearly if you remove the glove box.
Iíd send you pictures but Iím on an iPad cause my computer canít connect to the internet.
As you suspect, you will find many pictures on the internet.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #7 of 8 Old 02-22-2020, 07:04 AM
cjoffroad
cjoffroad's Avatar
1980 CJ7
Here you go.
cjoffroad is offline
post #8 of 8 Old 02-22-2020, 07:16 AM
John Strenk
1976 CJ5
That would be the blue line.
