CJ7 Frame Question - JeepForum.com
post #1 of 9 Old 09-16-2020, 04:27 PM Thread Starter
Jeepnstein
Jeepnstein's Avatar
1979 CJ7
CJ7 Frame Question
Hi all,
Its been a while since i've visited the site.......After owning my CJ for almost 20 years, i've gotten to the point of ripping her apart and rebuilding her. I almost have it fully down to the bare frame and I noticed something. It appears that there is a lot of welding slug on the top of the frame. I was wondering if that is something that is typical to see from the factory or has someone been in there before and did some repairs? I don't see anything that leads me to believe that the frame was damaged or rusted, but it just doesn't look quite right. What do you guys think???
Named Jeepnstein because its built with parts from other dead Jeeps.
Jeepnstein is offline
post #2 of 9 Old 09-16-2020, 04:50 PM
80cj
80cj's Avatar
1980 CJ5
I would expect something better from the factory.
80cj is offline
post #3 of 9 Old 09-16-2020, 04:50 PM
BrutusBlue
1982 CJ7
Looks normal to me...I have three frames that are completely original and have similar weld crud in different spots.
Here is one with welds like yours in the same area...
BrutusBlue is offline
post #4 of 9 Old 09-16-2020, 05:02 PM
BrutusBlue
1982 CJ7
The factory welds on CJ frames were never really good. Not uncommon for the front frame horns to come apart near the front cross member. Yours do not look like they will be an issue.
post #5 of 9 Old 09-16-2020, 06:44 PM Thread Starter
Jeepnstein
Jeepnstein's Avatar
1979 CJ7
Thanks guys......I had a feeling like the weld mess was a factory thing, even though I would expect more from the factory as well. Its good to know that I am not the only owner that has this.
post #6 of 9 Old 09-16-2020, 07:02 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
My frames have poor quality factory welding. even I could have done better.
Your frame looks quite good for its age. I would suggest an internal wax injection as well as an external paint. Glavanising is possible as a sacrificial coating but it is only really of value if you run in salt areas and even then it needs good preparation.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #7 of 9 Old 09-16-2020, 09:06 PM
STJP
Jeepnstein,
If you are not familiar with cavity wax to prevent rust inside of various parts, like a frame, Google 3M's Cavity Wax Plus. Also check out their applicator wands.
JS
STJP is offline
post #8 of 9 Old 09-17-2020, 07:19 AM
sonnychiss
1978 CJ5
Originally Posted by STJP View Post
Jeepnstein,
JS
Fluid Film is another option that's readily availabe at auto and farm stores, their website says it is made from "specially processed wool-wax, highly refined petroleum oils". I have been using it and it lasts for months and seems to perform well. I have not used the 3M product so I can't speak to which is better.
sonnychiss is offline
post #9 of 9 Old 09-17-2020, 04:48 PM Thread Starter
Jeepnstein
Jeepnstein's Avatar
1979 CJ7
Thanks for the advice guys....I definitely plan on doing some sort of internal frame protection, I just haven't had a moment to do any research. It would have been a whole lot easier if the interior part of the frame would have been somewhat accessible.
