CJ5 Engine Wiring Harness - JeepForum.com
post #1 of 6 Old 08-01-2020, 05:17 PM Thread Starter
Chainsaw58
Newbie
1980 CJ5
Does anyone know where I can buy an Engine Bay wiring harness for a 1980 C5J? I see the complete kits, but I only need the engine compartment. If you can't buy one, does anyone know where I can but a large wiring diagram, one that I can actually read?
Thanks
Chainsaw58 is offline
post #2 of 6 Old 08-01-2020, 06:05 PM
John Strenk
John Strenk's Avatar
1976 CJ5
You can downlad the wiring diagram here and go to Staples or something like that and print it up to any size you want.
https://oljeep.com/gw/81_tsm/wiring_diagrams.pdf
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #3 of 6 Old 08-01-2020, 07:05 PM
MrPeter63
1983 CJ7
MrPeter63 is offline
post #4 of 6 Old 08-01-2020, 09:36 PM
John Strenk
1976 CJ5
Originally Posted by MrPeter63 View Post
Just a note. That is for a 76 or 77 so some of the things are different like the bulkhead connector and the fuse box and ignition system is a Pres-o-light instead of a DuraSpark. The V8 alternator is a different design
But generally the basic stuff is the same. Just routed differently.
post #5 of 6 Old 08-02-2020, 08:51 AM Thread Starter
Chainsaw58
Newbie
1980 CJ5
Thanks guys for your help. This wiring is a mess and if it wasn't so expensive, I think I would just buy the complete wiring harness. I may have to just break down and do that.
Mike
post #6 of 6 Old 08-02-2020, 09:10 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
A lot of Jeeps are like that. I start by identifying what is original and take out everything else, which usually means taking off conduit and tape from the wires so I can see it. Then trace and fix each circuit, finally binding up the cables with electrical tape into a rough harness and then enveloping in flexible conduit so that it looks neat and rats cannot eat it.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
