CJ5 - Page 2 - JeepForum.com
 15Likes
post #16 of 32 Old 10-20-2019, 01:17 AM
IMMORTEN
IMMORTEN's Avatar
Originally Posted by Dwight_C View Post
I bought some tires. I went with a Kenda 32x11.50r15. At least I can drive it now. So on the to-do list: (1)fix the radiator hose, (2)get this rig up on a lift and see if there's something janky going on with the suspension/driveline making the rear end sit that far back.
It goes down the road well and it's not TOO terrifying at 65mph, so I suspect there's nothing super terrible going on with the driveline. I wonder if the previous owner set the rear end back to make the rear driveshaft longer after the 350 swap???
Further ideas, suggestions, and criticism are welcome.
Sent from my SM-G975U using Tapatalk
New tires look great, really cleans up the look of the Jeep
I agree; if you can take it up to speeds of 65 mph without feeling like you are a trying to control a sailboat during a storm, then I dont think the driveline is that bad.
Have you taken it to get an alignment, and have both the front and rear wheels inspected?
Sent from my iPhone using Tapatalk
IMMORTEN is offline
post #17 of 32 Old 10-20-2019, 01:20 AM
IMMORTEN
IMMORTEN's Avatar
Might be a stupid question, but is it possible to just take a utility knife and cut maybe 4 (ish) off the bottom part of the radiator hose, to eliminate that big upward turning loop where an air pocket will likely form?
pedal2themetai likes this.
IMMORTEN is offline
post #18 of 32 Old 10-20-2019, 06:23 AM
pedal2themetai
1956 CJ5
Yes you can just cut the bottom I stated that in my post.
pedal2themetai is offline
post #19 of 32 Old 10-20-2019, 10:48 AM
IMMORTEN
IMMORTEN's Avatar
Oh apologies for missing that
IMMORTEN is offline
post #20 of 32 Old 10-20-2019, 11:25 AM
80cj
80cj's Avatar
1980 CJ5
What transmission and transfer case is that? SM465/205? Probably the reason the drive shaft is so short. Having the rearend toward the rear as it is helps make room for the drive shaft.
80cj is offline
post #21 of 32 Old 10-20-2019, 03:10 PM Thread Starter
Dwight_C
Dwight_C's Avatar
1956 CJ5
I'm pretty sure it's an SM465 with a 205. It was built using a 79 Chevy pickup running gear. I think the SM420 is much earlier than that. Also, I had a few extra minutes and hooked up a tach. Cruises down the freeway at 65mph running 2500rpm.
'75 CJ-5 350/SM465
Dwight_C is offline
post #22 of 32 Old 10-20-2019, 04:01 PM
pedal2themetai
1956 CJ5
so I was most likely right about the upper hose being from a truck
post #23 of 32 Old 10-20-2019, 04:13 PM Thread Starter
Dwight_C
Dwight_C's Avatar
1956 CJ5
Yeah. As soon as I can drain the coolant, I'm going to cut a new hose that doesnt have a huge air pocket like that. Probably won't be driving it until I get that fixed.
'75 CJ-5 350/SM465
Dwight_C is offline
post #24 of 32 Old 10-21-2019, 05:39 AM
pedal2themetai
1956 CJ5
Hi, probably don't need to cut a new hose that one looks almost new just cut the end at the thermostat and turn it down to level?
good luck
tim
post #25 of 32 Old 10-21-2019, 09:27 AM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
i would consider swapping out the overly long shackles for shorter ones and put a proper set of springs in to get the lift you want. Long shackles tend to create sway in the vehicle and can lead to handling issues.
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
post #26 of 32 Old 10-21-2019, 10:21 AM
Fourtrail
1974 CJ6
I would look for a new correct 1.5" upper radiator hose as that one per the part number is 1.5" at one end and 1.25" at the other and it has already been cut once and stretched badly to fit over the thermostat housing.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #27 of 32 Old 10-21-2019, 10:43 AM
John Strenk
John Strenk's Avatar
1976 CJ5
HI, You might want to check and see if your wheel base is the same on both sides. This tire looks more centered on this side over the other one being way towards the back of the wheel well? Also X the measurment ( LF to RR hard points ) to check centering.
good luck
tim
Thank you. I just measured from the front of the spring perch to the center of the rear leaf spring eye bolt. It measured 20.5 inches on each side. When I can finally get it in the air, I'll do the cross measure. I also noticed something else interesting while I was down there. The spring perches welded on the axle have three holes. Is that normal for aftermarket spring perches?
Yes, This is interesting.
Yes, a lot of weld-in perches have 3 holes in them.
Looks like they are both in the center hole.
And you already checked the mount to the bolt on the spring is the same.
Still like to see center-to-center of the front to rear axle are the same.
It might just be the way camera perspective is making it look odd.
Dwight_C and pedal2themetai like this.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #28 of 32 Old 10-21-2019, 12:31 PM
pedal2themetai
1956 CJ5
HI, yes if the rear end is not centered it well give it some rear steer. When you step on the gas does it want to turn one way or the other and not drive straight that would be a sign of a misaligned rear end.
good luck
tim
post #29 of 32 Old 10-21-2019, 12:54 PM
80cj
80cj's Avatar
1980 CJ5
If you decide to move the rearend to the center perch hole position, you'll probably have to grind the height of your centering bolts down.
80cj is offline
post #30 of 32 Old 10-21-2019, 01:47 PM
Fourtrail
1974 CJ6
Those are the incorrect spring center pins. The head of the pin should be tight in the spring perch hole, if they are loose the spring will move back and forth and eventually break the center bolt.
