cj5 1979 amc20 wtf - JeepForum.com
post #1 of 5 Old 08-10-2020, 06:42 PM Thread Starter
rustbucketj10
cj5 1979 amc20 wtf
hello, rear wheel started to smoke. thought it was brakes. installed all new brakes. still smoked. turns out the wheel bearing is disintegrated. its an original 2 piece axle. got new bearing pressed on. BUT. i didnt remove old seal and put new seal on top of old. Im guessing i need to remove old seal and put new seal on. also i didnt packed bearing but not a ton. I am going to tear it all apart and remove old seal and replace w new one and pack bearing better. IS THERE ANYTHING ELSE I NEED TO KNOW??? ANY ADVICE OR TIPS WOULD BE GREAT RELATED TO NEW BEARING AND SEALS.
thanks, david
db
rustbucketj10 is offline
post #2 of 5 Old 08-10-2020, 08:36 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
I (and others) have not had good luck reusing a two piece axle after replacing bearings and seals.
With two of my CJ-5s (twice) The marriage of the hub and shaft neither lasted two months before I "spun" them.
I was driving normal (No hot dogging!) I got by, by welding the shaft to the nut and the nut to the hub until I could buy a one piece set.
When it happened with the other Jeep, I did the same thing----that time----lesson learned----reinforced as I saw it happen to other folks.
Others may have other thoughts----My suggestion is to go ahead and get the one piece axles.
----JEEPFELLER
JEEPFELLER is offline
post #3 of 5 Old 08-10-2020, 09:05 PM Thread Starter
rustbucketj10
oh gosh! not what i wanted to hear but thanks. If i cont. with the two piece. the inner seal, does the spring face toward the differential and the flat back part toward the bearing? thanks again.
db
post #4 of 5 Old 08-11-2020, 01:49 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
The Axle Nut is extremely high torque. Get a long bar and stand on it. This forces the splines to make a nest in the hub.
If it starts to creak, check the torque again. When they creak they are wearing and fretting on that join.
You can get 30 -40 years on a 2 piece axle, they do not break every day.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 5 Old 08-11-2020, 05:51 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
While not common, spinning an AMC20 hub does happen. new hubs are about 50-75 bucks and if you aren't looking to up grade to one piece axles but still need piece of mind, are a good investment (they are designed to have the splines cut on installation). Either way, it is imperative that the axle nut be torqued to a minimum of 250FT/LBS of torque.
You will need a special puller or a press for removing the old hub.
Inspect the drum and backing plate for any damage.
Insure to double check your end play on installation. The new bearings/seals may have changed it.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
