CJ to YJ frame - JeepForum.com
post #1 of 5 Old 11-03-2019, 05:00 PM Thread Starter
nitor
nitor's Avatar
CJ to YJ frame
Hi Jeep Gurus,
I'm sure this has been asked, but, I just bought a 1986 CJ7. It needs a frame. Is a 1986 CJ and a 1995 YJ frames the same? I guess my real question is, are CJ and YJ frames the same?
Regards,
Nitor
Thanks,
Jim
nitor is offline
post #2 of 5 Old 11-04-2019, 02:10 AM
only in a jeep cj
No. The YJ frame is 4 inches wider between the rails. Also 4 of the body mounts will be off.
Because the springs are wider apart, your axles will not fit. Engine mounts are welded to the frames in the YJ, so that would be an issue if you have the 6 vs 4 etc.
honestly, search for a CJ frame. You want to get an 82 to 86. Easy to spot as the front shocks have bolt on upper tower brackets.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 5 Old 11-04-2019, 06:38 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Is it 4" wider in the rear also?
I thought they only widened the front.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is online now
post #4 of 5 Old 11-04-2019, 07:36 AM
only in a jeep cj
Yes, wider in the rear as well.
Ed
1975 CJ-6 1983 CJ-8
post #5 of 5 Old 11-04-2019, 11:45 AM Thread Starter
nitor
nitor's Avatar
Hi Ed,
Thanks for the reply. I'll search for a CJ frame.
nitor is offline
