CJ Sport Cage Dash Tie-in's CNC PLASMA CUT - Page 4 - JeepForum.com
 5Likes
post #46 of 60 Old 05-23-2018, 09:31 AM
StoneTower
If there are images, I would love to see them. When I quoted your message, I see that there is a link to CJ-8.com and I believe that unless you are a member over there, you cannot see them on here as I do not see the link in the thread. It was only in the quote that I saw the link.
Originally Posted by CHIEFWAHO View Post
I worked this up for my brothers Scrambler with YJ windshield frame.
Kinda based if off of the kit Genright offers.
StoneTower is offline
post #47 of 60 Old 08-09-2018, 01:55 PM
Zorty
1983 CJ7
Bump to try and keep this alive in case anything is still available. Even a drawing or 3d file to try and get some made on our own.
Taking the plunge of swapping a YJ style family rear into my CJ, and would like to rebuild my front sport cage using the dash brackets. Come on!
Cutlass327 likes this.
Zorty is offline
post #48 of 60 Old 08-21-2019, 12:04 PM
Jim1611
Jim1611's Avatar
I'll 2nd that bump.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #49 of 60 Old 08-21-2019, 12:49 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
If someone makes these, please let me know if you will make a set to sell me, especially if they will not affect the VIN sticker on the dash of the 78s.
Rick
Cutlass327 is offline
post #50 of 60 Old 08-21-2019, 01:04 PM
Jim1611
Jim1611's Avatar
Got a picture of where that sticker is? If Jeremy doesn't have them I likely will make some.
My build thread
Jim1611 is offline
post #51 of 60 Old 08-21-2019, 08:10 PM
StoneTower
I would like to see some brackets with two gussets and a place for a 1" hardened bolt that could thread up into a threaded slug that is welded into the front hoop of a roll cage. It would make it easy to remove the brackets to remove the dash and access everything behind the dash.
post #52 of 60 Old 08-23-2019, 08:36 AM
twoscooterz
twoscooterz's Avatar
I'm still interested in a set too. Unfortunately, I discovered this thread right after the OP stopped making them...
'86 CJ7 Laredo, 258, Weber 38, DUI, T5 w/Hurst shifter, 4.56 Dana 30, AMC 20, Detroit TruTrac, Moser axles & Blue Torch truss, Dana 300, stock YJ springs SUA, 33" MTR's, Poison Spyder sliders, NewGen tank cover, Warn 9.5ti w/synthetic rope
twoscooterz is offline
post #53 of 60 Old 08-23-2019, 08:50 AM
Agar426
1974 CJ6
Count me in! I have your shackle hangers and they are works of art! I have two CJs, one is an '85 and the other is a '74....very similar configuration, but I am guessing the bolt holes are aligned differently. If I can find those details, would it be possible to do two versions? The intermediates get very little love....
WSS likes this.
Agar426 is offline
post #54 of 60 Old 08-23-2019, 07:27 PM
StoneTower
Maybe he could make them with a paper template to tape on the backside of the bracket that the user could use to drill the correct hole pattern.
Does anyone know why the OP stopped making the brackets?
post #55 of 60 Old 08-23-2019, 07:50 PM
Jim1611
Jim1611's Avatar
I will, thanks! There might be an early 70s Jeep close by that I can measure. I'll check in the next few days. Thanks for the compliment on the hangers. I'm glad you like them!
I think Jeremy sold his plasma table some time ago. One thing I'd like to avoid on the later CJs is covering the speaker grille slots. Some I've seen do that and I really see no need to do that. They should also work if the owner wants to retain the dash cover too.
Agar426 likes this.
My build thread
Jim1611 is offline
post #56 of 60 Old 08-24-2019, 01:40 PM
Jim1611
Jim1611's Avatar
Is the dash on a 74 the same as that of a 65?
My build thread
Jim1611 is offline
post #57 of 60 Old 08-24-2019, 04:13 PM
Agar426
1974 CJ6
Count me in! I have your shackle hangers and they are works of art! I have two CJs, one is an '85 and the other is a '74....very similar configuration, but I am guessing the bolt holes are aligned differently. If I can find those details, would it be possible to do two versions? The intermediates get very little love.... <img src="https://www.jeepforum.com/ubb/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
Good question! My guess would be no because the tub was new in '72. Double D Fabrication makes all three vintages as does Aqualu for their aftermarket dashes, so that may be an indicator that there are three templates.
Agar426 is offline
post #58 of 60 Old 08-24-2019, 04:21 PM
StoneTower
Hey Jim...let me fix it for you...
www.crabtreetool.com (Crabtree Shackle Hangers & DASH BRACKETS)
post #59 of 60 Old 08-25-2019, 08:00 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I put the 1" mark over the bolt, and it still doesn't touch the sticker. In the 2nd picture I have the end of the tape above the emissions sticker that was painted over. I would imagine that if you made them to clear the sticker, it would also clear the speaker.
78 CJ5 302HO, T177/D300, 86 WT 30/44, Aussie F/R
Rick
post #60 of 60 Old 10-06-2019, 07:24 AM
twoscooterz
Are there any new developments on this? I'm looking for something new to add to my Christmas wish list!
Or-fab sport bar cage FATHERNSON Jeep CJ Forum 4 07-22-2013 06:02 PM
Special dash pad for hard doors and O-R Fab sport cage jatepper Jeep CJ Forum 6 01-06-2011 10:20 AM
Or-Fab Sport Cage from CJ5 fit CJ7? connor014 Jeep CJ Forum 2 09-27-2008 10:19 PM
? 4 those with the Kentrol sport cage 78treehugger Jeep CJ Forum 1 06-11-2008 05:13 PM
77 cj7 bolt in sport cage?? cwbrg Jeep CJ Forum 4 08-24-2005 09:45 AM
