CJ of the Month for October 2014.. VOTE NOW!! - JeepForum.com
View Poll Results: CJ of the Month for October.. VOTE NOW!!
vsanzbajo 35 70.00%
1tonmut 6 12.00%
Mlaughlin8 9 18.00%
Voters: 50. You may not vote on this poll
post #1 of 3 Old 09-18-2014, 01:28 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Time to Vote!!
Time to Vote!!
Originally Posted by vsanzbajo View Post
Specs: Jeep CJ 7 Laredo
Year of CJ: 1986
Engine: 4.2 L 6 CYL Mopar FI
Transmission: 5 Speed Manual T5
Transfer Case: Dana 300
Front Axle: Dana 30
Rear Axle: Dana 44
Suspension: Rancho RS 5000 with 3 inch Lift
Tires: 33s All Terrain
Additional Mods: Mopar FI
Originally Posted by 1tonmut View Post
Specs-Cj7 laredo
Year-1982
Engine-5.0 ford roller cam v8
Transmission-4 speed T18 with 6.32:1 granny low
Transfer case-Atlas II with 5:1 low range
Front axle-Dana60 4.56:1 shortened 4",posi,springless kingpins,flange yoke
Rear axle- GM 14 bolt full floater 4.56:1 spooled
Suspension-Spring over lift,wrangler 3" springs,shackle reverse,limiting straps
Tires-37" H1 surplus tires on recentered H1 beadlock wheels w/inserts
Additional mods-
9,500 lb winch with 100' arachni synthetic winch line.
Anti wrap bar on rear axle.
Crossover steering with high psi P pump and fluid cooler.
108watt led light in front and a dozen 3watt led's underneath for crawling lights.
H4 headlight conversion with 130 watt high beams off road.
Poison spider body wrap and rocker knockers.
Flush mount tail,turn,brake lights and matching style front turn signal lights
15 gal fuel cell and regulated recirculating fuel system.
Braided steel hoses with AN fittings on fuel lines,vac booster line,brake flex lines.
Heater craft mojave heater.
Front roll cage.
Crawling bumpers.
Co2 and air compressor.
Cut front fenders narrower 3", 3" tube flares in rear.
Aluminum radiator.
dual cv drive shaft up front , cv drive shaft in rear.
Remote oil filter and oil cooler.
Just installed GoPro.
And I did 99 percent of it myself !
[quote=Mlaughlin8;25558266]Specs: jeep cj5 trail rig
Year of CJ: 1980
Engine: rebuilt 4.2ltr bored .060 over, header, magnaflow exhaust, gm ignition, weber carb, flow cooler water pump, optima red top
Transmission: t176 rebuilt to stock specs
Transfer Case: rebuilt Dana 300
Front Axle: rebuilt Dana 30, warn hubs, 3.54 ratio
Rear Axle: model 20, 3.54 ratio, tom woods cv driveshaft
Suspension: 4" superlift springs, rubicon express shocks, steering box brace, braided ss brake lines, procomp drop pitman arm, 1" shackle lift front, 1/2" shackle lift rear, 1.25" day star body lift
Tires: 33x10.5x15 bfgoodridge km2, 15x8 ultra gauntlet wheels
Additional Mods: built roll cage off of factory rollbar, corbeau seats, marine stereo, home built bumpers, rocker gaurds, tire carrier, and gear mounts, herculiner paint that has held up extremely well! Milemarker 8000 winch. Warn lights 2pr.
BESRK is offline
post #2 of 3 Old 09-18-2014, 04:48 PM
AmazingBlu
AmazingBlu's Avatar
1983 CJ7
AmazingBlu is offline
post #3 of 3 Old 09-27-2014, 08:39 AM
The_Goob
The_Goob's Avatar
If anyone cares to look at the YJ contest https://www.jeepforum.com/forum/f12/v...yjotm-2731530/
YJoTM~April '14~June '15~April '17
The_Goob is offline
Closed Thread
