CJ Jeep theft prevention ideas - JeepForum.com
 30Likes
post #1 of 55 Old 06-20-2020, 04:07 PM Thread Starter
medic44
Lightbulb CJ Jeep theft prevention ideas
What is the best way to prevent theft of my newly acquired CJ5? I am thinking the “old school” Club device....
81azcj7 likes this.
medic44 is offline
post #2 of 55 Old 06-20-2020, 04:15 PM
LumpyGrits
Kill switch the cuts the GND wire to the coil.
Engine will crank. Just won't start.
Gary
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 55 Old 06-20-2020, 04:50 PM
devildog80
devildog80's Avatar
1981 CJ5
Will this work?
devildog80 is offline
post #4 of 55 Old 06-20-2020, 05:36 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Removable steering wheel.
Wheel boot.
Lock the clutch/brake pedal together.
Hidden kill switch (or three)
Hoss
jeepster4245 likes this.
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is online now
post #5 of 55 Old 06-20-2020, 05:50 PM
Flundertaker
Question
Just curious the cause of your concern? Is your parked outside nightly or park in sketchy areas? I hear of Jeep theft once in a while in my reletive AO but its always a loaded and pimped JK or JL with 20's, a banging stereo and 25k in aftermarket goodies added to it. Are older CJs much of a theft target?
Flundertaker is offline
post #6 of 55 Old 06-20-2020, 06:40 PM
Jeffncs
Jeffncs's Avatar
Kill switch is easy... I’ve actually used 2 in the past...1 dummy and 1 real one.
Remove the coil wire
Fuel shut off valve
Chain the clutch in the “up” position to the steering column
Professional Knucklehead
Jeffncs is offline
post #7 of 55 Old 06-20-2020, 06:50 PM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
Manual transmissions work against millennials 😃
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is offline
post #8 of 55 Old 06-20-2020, 06:53 PM
keith460
keith460's Avatar
Originally Posted by Flundertaker View Post
Just curious the cause of your concern? Are older CJs much of a theft target?
If they are easy to take for a joy ride or have valuable OEM parts that thieves will sell for handsome prices at auction.
My friend in Delaware has an original CJ-7 that 7 or 8 years ago got the OEM ash tray, radio knobs, horn button and windshield knobs taken while parked at a Home Dept just because a tool was not needed to take them. He swears he saw the horn button on eBay shortly thereafter. He's still looking to replace the radio knobs.... you just never know.
Even though I have a hidden kill switch for the ignition that I use when parked in public places, I always worry of the small simple parts that are impossible to find and can be gone in a heartbeat. Insurance may cover it, but finding irreplaceable OEM parts can be a lifetime quest.
258 likes this.
1984 CJ-7 Renegade
keith460 is offline
post #9 of 55 Old 06-20-2020, 08:14 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
Pull fuel pump relay. Keep garaged. .45 ACP. All these ideas are worthless if ur not home. Thieves here use tow trucks so just a quick winch onto a tilt bed truck and bye bye. There is a detailed thread on pirate about these and more countermeasures.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #10 of 55 Old 06-20-2020, 10:32 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
An aftermarket motion alarm under a locked hood
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #11 of 55 Old 06-21-2020, 05:55 AM
bob4703
1974 CJ5
There is another post that was revived recently about this subject. It gives many good and few not so good suggestions. I just have a quick release negative battery cable, but honestly it is not so much a theft deterrent as it is to conserve the battery charge during periods of inactivity.
The US Army will weld a logging chain to the floor of their tactical vehicles and chain the steering wheel rigid. Of course the weak point is the $2 padlock that any HF bolt cutters can open.
Today most thefts are done by backing up a rollback wrecker to your vehicle. It truly will be gone in 60 seconds!
Let us know what you decide to do. Good luck!
Paved roads are prime examples of government over spending!
bob4703 is offline
post #12 of 55 Old 06-21-2020, 07:06 AM
DV915
DV915's Avatar
1976 CJ7
It’s theft by tow truck that worries me the most.
I’ve always been uncomfortable with my CJ parked all night at some interstate motel when traveling to the trail.
I’ve given theft protection considerable thought and agree with Jeep Daddy, an aftermarket security system with alarm and kill function. One that also sends a signal to a key fob when your vehicle is tampered with.
DV915 is offline
post #13 of 55 Old 06-21-2020, 10:10 AM
Splinter
1980 CJ5
I am going to install a manual fuel valve operated from beside the seat. With it off the 360 amc will not run long. There are also plans on this forum for a reed operated switch mounted behind the dashboard that interrupts the ignition. Just place a magnet �� on the location of the switch and power is supplied to ignition.
Splinter is offline
post #14 of 55 Old 06-21-2020, 10:23 AM
jeepdaddy2000
1971 CJ5
One of the biggest thing I've found is !^%$#*&^%*& thieves stealing things out of the Jeep (hence, cheap stereo, speakers, etc).
Having a motion sensitive alarm should also help negate this as well.
Submariner and DV915 like this.
Chesty Puller
post #15 of 55 Old 06-21-2020, 04:29 PM
43Duc
43Duc's Avatar
1982 CJ8
I've got a Grant steering wheel with the Grant "No Wheel, No Steal" kit installed. Works great, give me peace of mind. Manual trans keeps my kids from driving it.
Submariner likes this.
1982 Jeep Scrambler
43Duc is offline
