CJ Heater Box Restoration...pic heavy!! - Page 6 - JeepForum.com
 32Likes
post #76 of 453 Old 11-12-2010, 10:01 AM
jarrodblake
1978 CJ10
Bump so I can find I later to day when I'm at the auto parts store
jarrodblake is offline
post #77 of 453 Old 11-18-2010, 09:15 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by rixcj View Post
NOTE: FOR THOSE OF YOU WHO HAVE READ THAT A '73 BLAZER MOTOR W/AC IS THE CORRECT ONE...TAKE IT FROM ME...IT DOESN'T WORK FOR EVERYONE!!
I found out the hard way that it was wrong for me, anyway. So, I called NAPA and ordered NAPA PN 655-1039, and this was the right one.
The difference...
So why exactly didn't the 73 Blazer w/ AC motor work for you?
The only obvious difference based on your pic is the size.
2Xtreme is offline
post #78 of 453 Old 11-18-2010, 09:29 AM
Jeepican
Jeepican's Avatar
1976 CJ5
did you guys prime the box before painting?
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #79 of 453 Old 11-18-2010, 11:24 AM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
If you look at the size of the hubs (that the shaft comes up out of) above the mounting flanges, you'll notice that one hub is taller than the other. Trust me...it doesn't fit. At least on my jeep it didn't.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #80 of 453 Old 11-18-2010, 11:30 AM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
I primed the metal parts, only. I just scuffed up the plastic parts with a Scotchbrite pad, wiped it all down with denatured alcohol, and painted it. I used Napa's Underhood Black paint because of the low luster sheen that it has. If you don't mind a glossier finish, Krylon has a line of spray paints designed for plastics. It may be offered in different glosses, but I'm not sure.
Rich
rixcj is offline
post #81 of 453 Old 11-18-2010, 11:42 AM
Jeepican
Jeepican's Avatar
1976 CJ5
Rich
Ya i like the semi gloss look better i may just use rustoleum on mine.... how's it been holding up?
-Barney Fife-
Jeepican is offline
post #82 of 453 Old 11-18-2010, 12:37 PM
twildt
twildt's Avatar
1978 CJ5
hey rixcj, how much was the total cost of your restoration on this project?
Habitual MSC#2 in summer and MSC#4 in winter.
My CJ Rebuild -
My Youtube Channel - http://youtube.com/tawildt
Other Pics - http://s1116.photobucket.com/albums/k579/twildt/1978%20CJ-5/
twildt is offline
post #83 of 453 Old 11-18-2010, 12:54 PM
jarrodblake
1978 CJ10
i just finished mine but im starting to thing my jeep is running cold as its only gets up to 158* and the air is worm but not hot. i also have a new aluminum 2 core radiator and a aluminum heater core. how hot should my jeep get?
post #84 of 453 Old 11-18-2010, 10:52 PM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
Rustoleum would probably be just fine. The preparation (solvent cleaning) is the key! Mine is in storage, in my shed. I rebuilt it for a project CJ5 that I'm building from the ground up. I haven't gotten to the point of installing the heater box, yet. Just sitting in the shed, though, it's held up fine...no flaking or anything.
If you're asking about the cost of JUST the heater box restoration, I had a lot of the stuff in stock, already. I had to buy the foam, the new blower motor, a new heater core (but didn't end up using it), and a new heater core tube foam seal.
The foam wasn't cheap. I bought it from Mc-Master-Carr. The reason that I didn't buy the local hardware store foam strip roll, is because I didn't want to piece-meal strips together, plus, I've used the stuff I bought, before, for industrial fabrications that I've built for my customers, and it's held up well. It's waterproof, as well. Not all other foams are. I only want to do this once! I forget the exact price, but I think it's listed in this thread, somewhere.
The blower motor was about $23.00. I'd say that the materials that I bought that I ended up using probably cost around about $75.00. The foam was the most expensive part, but there's plenty left over for other uses. It's very handy to have.
Rich
rixcj is offline
post #85 of 453 Old 11-19-2010, 07:48 AM
Blue84JeepCJ7
Blue84JeepCJ7's Avatar
This thread is the rebuild of a spare heater box that I had.
Where can I get the cable that is inside the box? I can find all other cables on ebay, but not the inside the box!
84 CJ-7
Chevy 350, Mild Cam. (325hp)
Summit (600 CFM) Carb.
1987 TH700R4 "K" Case
32x11.5x15 Cooper ATs
3" Body Lift
Be-Cool Radiator
Black Magic 175 Cooling Fan
Blue84JeepCJ7 is offline
post #86 of 453 Old 11-19-2010, 08:00 AM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
Is everything operating properly? Good circulation, engine timing is good?
Are you running a 160 degree thermostat? Or possibly, is your thermostat opening prematurely, before it's designated temperature? You could try using a 195 degree thermostat.
You can either buy another used heater box, and hope that the cable inside that one is good. That's risky.
Or...do what was done in post #62 of this thread.
Rich
rixcj is offline
post #87 of 453 Old 11-19-2010, 08:16 AM
Blue84JeepCJ7
Rich
Actually my cable is good but the plastic retainer ring is gone! I will check out #62
84 CJ-7
3" Body Lift
Be-Cool Radiator
post #88 of 453 Old 11-19-2010, 08:18 AM
Blue84JeepCJ7
Post #62 is perfect! Thanks!!!!!!!
84 CJ-7
3" Body Lift
Be-Cool Radiator
post #89 of 453 Old 11-22-2010, 11:21 AM
Davidnex
Davidnex's Avatar
1979 CJ5
Heater Blower Motor upgrade
Need to punch larger hole in firewall for motor upgrade
79 CJ 5 Frame up Build
https://www.jeepforum.com/forum/f8/79-cj-5-frame-up-1092681/
Davidnex is offline
post #90 of 453 Old 11-23-2010, 11:40 AM
Davidnex
Davidnex's Avatar
1979 CJ5
Fresh Air Box
Start of air box rebuild, removed and cleaned motor resistors
Davidnex is offline
Cj7 restoration tiko_joe Jeep CJ Forum 4 05-22-2008 07:26 AM
'54 CJ-3B Restoration Mayfair_Jeeper Jeep CJ Forum 9 02-24-2008 02:33 PM
CJ5 Restoration CJ Runner Jeep CJ Forum 7 10-15-2007 08:32 AM
Restoration of a CJ-5 Roy Jeep CJ Forum 4 08-01-2007 02:34 PM
Restoration-What first? Viper23 Jeep CJ Forum 3 11-26-2004 12:51 PM
