CJ Heater Box Restoration...pic heavy!! - Page 4 - JeepForum.com
 28Likes
post #46 of 448 Old 11-04-2010, 12:41 PM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
Originally Posted by Davidnex View Post
Restoring my box, the internal cable is inoperable, Does anyone know where to buy?? thanks
Either a junkyard, or call these guys...
items - Get great deals on Cherokee 84-01 XJ Other Parts items on eBay Stores!
They have lots of jeep parts, and will ship anything.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #47 of 448 Old 11-04-2010, 01:11 PM
way_of_life
way_of_life's Avatar
1978 CJ7
quadratec.com
if you can't find one for a cj5 then try the cj7 ones
°lllllll°
way_of_life is offline
post #48 of 448 Old 11-04-2010, 04:04 PM
FMXJ
1989 XJ Cherokee
heater box / defrost duct
I just used some insulation tape I had laying around. I ran it round the edges of the flaps, seems to work just fine. My cardboard defroster duct was all wore out and busted up. Instead of spending big bucks on another one I used 2 inch pvc pipe to make one that wont rot or rust. It fits nice and snug up in the channel and will seal up tight so air flow wont be lost. If any body is interested in how I did it shoot me a line and I'll send pictures.
FMXJ is offline
post #49 of 448 Old 11-04-2010, 04:42 PM
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
I don't believe you can buy the inner cable new. Did you try running some Kroil or similiar down the wire to free it up? That is what I did and worked it in and out, just becarefull not to kink it.. Hint: Don't remove it from the box yet. It is a PITA to get out and a bigger one to put back. If that doesn't work you could make one from one of the other cables that go to the dash. The dash cables are available new.
Guy Smilie is offline
post #50 of 448 Old 11-04-2010, 10:02 PM
Davidnex
Davidnex's Avatar
1979 CJ5
Would have try Blaster,but cable was already rusted in two... But you have a good idea< I did think of building one out out dash cable.. it will require the the longest one,, working today on that.
Davidnex is offline
post #51 of 448 Old 11-05-2010, 02:59 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Why not just post them here?
Rick
Cutlass327 is offline
post #52 of 448 Old 11-05-2010, 10:32 AM
Davidnex
Davidnex's Avatar
1979 CJ5
Nice thread, very helpful, brought the Napa motor, right on and less than online stores..
79 CJ 5 Frame up Build
https://www.jeepforum.com/forum/f8/79-cj-5-frame-up-1092681/
Davidnex is offline
post #53 of 448 Old 11-05-2010, 01:36 PM
way_of_life
1978 CJ7
this reminds me--
Although I didn't really do extensive searching, everything I was find was expensive (for the motor) but you can refurbish them in most cases by taking a wire and getting the rust off and then giving it a healthy dose of oil
if you have a battery charger, set it to 12v and hook it up to the motor to let the oil work its way in, and then wipe it off and give it some paint. It worked perfectly for mine
°lllllll°
post #54 of 448 Old 11-05-2010, 06:35 PM
MoC
MoC's Avatar
Another tip to add here that I found out when I did mine and upgraded to the blazer blower motor it to get it from AutoZone and not Advanced Auto. For what ever reason the Advanced Auto one did not come with the plug that goes in the motor unused port. I had the guy check the boxes of all three in stock and it was not there. Had to go to autozone.
MoC is offline
post #55 of 448 Old 11-05-2010, 09:05 PM
Davidnex
Davidnex's Avatar
1979 CJ5
$22, you can't go wrong, tonight will rebuild internal temp adjust cable(not available anywhere), will post results with pics
Davidnex is offline
post #56 of 448 Old 11-05-2010, 09:10 PM
chet44
Too bad you don't live closer to me. I know a local guy who probably has that cable, at least he had it when I needed one. He used to own several Jeep dealerships, since retired, and as a result he has a huge repository of original factory Jeep parts.
chet44 is offline
post #57 of 448 Old 11-05-2010, 09:11 PM
chet44
X2 I got mine from NAPA and theirs did not have the plug either, I had to make one.
chet44 is offline
post #58 of 448 Old 11-05-2010, 09:28 PM
Jeep-N-0311
I've been doing some looking and experimenting, Have used the Bronco blower motor on my CJ's for 15 years - an improvement, but still .... not REALLY perfect. Have found the Blower motor from the Grand Caravan (Late 80's). Has MUCH more "Bite" in the squireel cage fins, dual-sided squirrel cage, and REALLY moves the air (remember, it moves enough to heat a mini-van. We've run it (hand-held, straight wired to battery) side by side with the bronco fan ... NO comparison ... The Grand Caravan motor moves TONS more air. Unfortunately, (we think) that it's set up (bearings, etc) to be mounted vertically, rather than horizontally, so, there's another engineering issue. With the amount of air it moves, a custom made box could:
A) use a larger (or doubled) heater core &
B) (presumedly) BOTH, heat low (floor or waist), AND defrost, effectively.
Oh, and, I bought a full set of cables (Quadratec, I think) about 6 months ago
Jeep-N-0311 is offline
post #59 of 448 Old 11-05-2010, 11:05 PM
Skerr
Skerr's Avatar
I would appreciate that.
Rich- Did you have any other cable problems? Broken ends, frozen, etc.? Besides what David is doing I'd like to see any pics you might have accumulated. Also, do you have a source for the teflon washers, or an alternative?
Thanks
Kerrdog
Go Fish! <*////><
Skerr is offline
post #60 of 448 Old 11-05-2010, 11:48 PM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
Thanks
I didn't have any cable problems, Scott. What type of pictures did you have in mind? Most are in this thread, but I may have a few more.
I had the teflon washers in stock, but I bought them a few years ago from McMaster-Carr.com.
You probably don't have to use teflon... stainless, or steel ones would probably work fine. They're only used to center the flap and take up the extra space on the rod.
I haven't had a chance to install the heater box, yet. I've been so busy with everything else in life, that the jeep has taken a back seat. But, this winter I plan to make some progress, hopefully.
Rich
rixcj is offline
Cj7 restoration tiko_joe Jeep CJ Forum 4 05-22-2008 08:26 AM
'54 CJ-3B Restoration Mayfair_Jeeper Jeep CJ Forum 9 02-24-2008 03:33 PM
CJ5 Restoration CJ Runner Jeep CJ Forum 7 10-15-2007 09:32 AM
Restoration of a CJ-5 Roy Jeep CJ Forum 4 08-01-2007 03:34 PM
Restoration-What first? Viper23 Jeep CJ Forum 3 11-26-2004 01:51 PM
