CJ full hard door window regulator grommets - JeepForum.com
 3Likes
  • 1 Post By cjoffroad
  • 1 Post By 43Duc
  • 1 Post By wkdavistx
post #1 of 9 Old 11-09-2019, 08:16 AM Thread Starter
cjoffroad
cjoffroad's Avatar
1980 CJ7
In my efforts to restore the doors for my '78 CJ7, I ran across an issue of trying to find some replacement parts for the door glass.
Searching online it seems the little piece of plastic is called the regulator grommet.
It's the piece that snaps into the glass and allows the regulator slide to attach to via screws.
The ones on mine were pretty brittle and a few of the 'legs' had broken off and after getting my door back together and rolling the window up and down a few times the little grommet broke and will no longer retain itself in the glass hole it snaps into.
Apparently this little grommet is a discontinued part. Still available if you dig for it however pricey. About 25$ apiece
epay
epay
Interested to see if anyone has come up with something that works thats not so costly. TIA
cjoffroad is offline
post #2 of 9 Old 11-09-2019, 08:31 AM
chatham
here are a couple of places you might try
https://cliphouse.com/
https://the-clip-house.myshopify.com/
chatham is offline
post #3 of 9 Old 11-14-2019, 01:54 PM Thread Starter
cjoffroad
cjoffroad's Avatar
1980 CJ7
Here are some more pictures of the grommets
post #4 of 9 Old 11-14-2019, 02:23 PM Thread Starter
cjoffroad
cjoffroad's Avatar
1980 CJ7
It just so turns out that BMW uses a similar setup on some of their vehicles door glass as well. The holes in the glass turn out to be 1/2" in diameter same as our jeep glass. Replacement clips for these are readily available and about a $1.50 apiece.
I found several videos on Youtube on how they fix their issues and it works for our jeep as well
The black clips are available from amazon. Just search for BMW X5 regulator clip
Then pickup a set of Hillman Truss Slotted 0.625 in License Plate Screws #884270 from Lowes
Insert the license plate holder into the black clip
Use the supplied screw with the license plate kit from lowes to attach the regulator slide rail.
Hopefully this will help someone in this situation fix their problem by not having to spend 25$ per grommet.
jc_chandler likes this.
post #5 of 9 Old 04-27-2020, 04:51 PM
43Duc
43Duc's Avatar
1982 CJ8
This was a big money saver for me this week! Worked like a charm - love this place!
cjoffroad likes this.
1982 Jeep Scrambler
43Duc is offline
post #6 of 9 Old 01-06-2021, 03:16 PM
wkdavistx
wkdavistx's Avatar
1983 CJ7
Thank you, cjoffroad!
Definitely saved me some money! My only problem is that one of the license plate screws in each door came out, so I had to go back in. I used some #10 stainless machine screws, washers and nuts. Works like a charm! Don't forget a little grease in the track to keep things moving smoothly.
1983 CJ7 on a 4" lift and 33's
wkdavistx is offline
post #7 of 9 Old 01-07-2021, 04:32 PM
Jim1611
Jim1611's Avatar
It's the crowd here. Everyone is helpful and allot of experience!
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #8 of 9 Old 04-19-2021, 08:33 AM
GadgetsYJ
Does anyone know where you can net new replacement slide rails? Or what the actual name or Part number would be.
GadgetsYJ is offline
post #9 of 9 Old 04-19-2021, 08:29 PM Thread Starter
cjoffroad
cjoffroad's Avatar
1980 CJ7
I've seen them referred to as slide rails, guide rails, regulator track arm and any combination in between.
Unfortunately it looks like new ones are getting hard to find and quite costly.
New
Good used
door , glass , grommet , regulator , replacement
