CJ File Sharing....DXF, DWG - Page 5 - JeepForum.com
 20Likes
post #61 of 82 Old 12-05-2018, 06:47 AM
John Strenk
John Strenk's Avatar
1976 CJ5
It's just hibernating for the winter.
trailhead2004 likes this.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #62 of 82 Old 03-08-2019, 03:56 AM
julienpatrick
Thanks
julienpatrick is offline
post #63 of 82 Old 03-28-2019, 06:46 AM
John Strenk
1976 CJ5
Wiring chart LM7
post #64 of 82 Old 11-26-2019, 04:37 PM
jchal3
1934 CJ7
Is there a file for a gear shift cover for a cj on here anywhere?
Sent from my SM-N960U using Tapatalk
jchal3 is offline
post #65 of 82 Old 01-05-2020, 07:57 PM
cflock
Anyone have a file for a cj7 front and or rear bumper?
cflock is offline
post #66 of 82 Old 01-06-2020, 12:14 AM Thread Starter
WSS
Graduate U-Tube Univ.
WSS's Avatar
Most rears for CJ's are from 2" x 4" tube in .1875 or .0250 wall. Most use a trailer bearing system like AtoZ sells for the swingout.
The front...........
I have a dxf file base for a TJ and have since modified it for a YJ, we are getting closer to a CJ. If you think you can use them, post up here and I will get them uploaded.
The family TJ build:
non stock CJ's:
My CJ5 Build:
WSS is offline
post #67 of 82 Old 01-07-2020, 05:45 PM
cflock
Very nice! I think I could use that and modify it to my needs. I would appreciate if you would upload those files.
cflock is offline
post #68 of 82 Old 01-17-2020, 10:05 AM Thread Starter
WSS
WSS's Avatar
I'm going to come back later and add pics. Just wanted to get the files here for you to use.
TJ Bumper parts
John Strenk likes this.
non stock CJ's:
My CJ5 Build:
WSS is offline
post #69 of 82 Old 01-17-2020, 10:09 AM Thread Starter
WSS
WSS's Avatar
YJ specific parts, many of the TJ parts are the same. I modified the TJ front drawing to be in two pieces to avoid a press brake operation.
non stock CJ's:
My CJ5 Build:
WSS is offline
post #70 of 82 Old 01-17-2020, 10:12 AM Thread Starter
WSS
WSS's Avatar
Here are some light bar and other mics mounts for the bumper project.
non stock CJ's:
My CJ5 Build:
WSS is offline
post #71 of 82 Old 01-17-2020, 12:53 PM
John Strenk
1976 CJ5
Keep 'em coming!!
post #72 of 82 Old 01-20-2020, 10:53 PM Thread Starter
WSS
WSS's Avatar
Here are some pics of the project on the TJ. The YJ specific parts will bring it closer to a CJ hopefully. If you have specific needs or find a solution, post up here, I'll keep an eye.
One thing I must mention, CJ;s have different frame widths that change at least once between '72 and (Mr. Adams year I think) '77. We found this out making gas tanks. LOL
Ok, this pic shows the top and front on a TJ, the YJ "front" is two files/pieces to eliminate the bend and need for a big press brake.
This pic shows the top only using stock bolt hole pattern. I did slot these holes but not enough to cover TJ to YJ, just enough to cover bent frames. Here will be the big issue for the CJ, what is the bolt pattern??
Here you can see the curve, the curve on the two piece is more usable as you can angle to your taste:
The shackles are 1" A36/mild plate
Note plate at back of shackle, it is right in line with the frame (of a TJ), we will need to address this too. I suppose it is ok to be out of line of frame, it just seemed the right spot to place.
Weld up inside before capping:
The weld between bottom and front plate was a little custom, I had to trim it a little and fold it into place (beat it to fit).
The bottom file posted has a relief cut in on driver side to clear the steering box, dunno if CJ's are going to need it, or perhaps a deeper relief.
Once fit, weld it up.......
I like the ground finish, so I spent some time grinding down the welds
I included the specs on the stinger hoop, any shape will work really, or no stinger at all.
The files for the light bar are made to fit around a Warn XD9000i, can be modified to fit any winch. The idea is you can fit random or single bar lights that adjust together by loosening side bolts and rotating whole bar
Anderson mount for jumper cables:
bulkhead mount for air:
Light var details:
Ready to roll
W/Rigid infrareds:
non stock CJ's:
My CJ5 Build:
WSS is offline
post #73 of 82 Old 03-09-2020, 07:33 AM
jchal3
1934 CJ7
Cj7 frame panels
Here are some patch panels I made for my CJ7 frame this weekend. Hopefully they will help someone out.
Sevenseejay likes this.
jchal3 is offline
post #74 of 82 Old 03-12-2020, 03:14 AM
Sevenseejay
1981 CJ7
Very good job! Thank you so much!
Do you have some photos of the cut parts? I don't understand where they go some patches..
Sevenseejay is offline
post #75 of 82 Old 03-12-2020, 05:07 AM
jchal3
1934 CJ7
Here is a few....I'll take more as I weld them in
jchal3 is offline
cad , cj , cnc , dwg , dxf
