CJ Dash Restoration.... that classic look! - Page 22 - JeepForum.com
 8Likes
post #316 of 343 Old 04-14-2015, 12:38 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Anyone have some advice / instructions for the heater box? I have a brand new dash with all new parts, the only electrical component left inside the Jeep that isn't new is the heater.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #317 of 343 Old 04-14-2015, 03:49 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Did you just wan't to replace just the electrical stuff for the heater or new parts all around.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #318 of 343 Old 04-14-2015, 09:26 AM
orange150
1982 CJ8
Does anyone know if the dash overlay will support a radio? I want to run a vintage vibes or retrosound radio but the PO cut out the dash to accommodate a newer head unit
'82 CJ-8
258/AX15/D300
OME YJ 2.5"/31s
D30/D44/3.73s/Truetracs
orange150 is offline
post #319 of 343 Old 04-14-2015, 01:47 PM
agear
Not really. It's flexible. It would be moving around and probably start to pull the overlay off. Maybe one of those stainless steel overlays would work if they make them for the two post radio. If you were really desperate you could herculine it and make it look pretty similar to the plastic black overlay as my herculiner in my jeep matches my overlay pretty good.
Where did you get that voltage and oil pressure gauge ? what brand are they ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #320 of 343 Old 04-14-2015, 06:04 PM
John Strenk
1976 CJ5
I think those are AMP meters and a Mechanical oil pressure gauge.
Called "MW" or "MAKE WAVES" gauges. Also try "Internatonal MW Gauges"
JC Penny sells somes for sure
http://www.jcwhitney.com/make-waves-...7290d21576u0j1
http://www.jcwhitney.com/gauges/inte...1576j1s21.jcwx
post #321 of 343 Old 04-14-2015, 07:04 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Yes? I haven't decided yet, cost depending. I would like something easy I can just bolt in, but I haven't found anything like that online.
Andy, KD8EIA
Grewe02 is offline
post #322 of 343 Old 04-15-2015, 05:50 PM Thread Starter
keith460
keith460's Avatar
No, the overlay is a textured plastic sheet, strictly cosmetic.
I think if that were my dash, that was hacked for DIN radio, I would make a plate for the OEM type standard two knob radio and attache the plate with countersunk screws. Then use the plastic dash overlay to cover it up, and make it look OEM.
1984 CJ-7 Renegade
keith460 is online now
post #323 of 343 Old 12-02-2015, 09:22 AM
onetouchdesign
1976 CJ7
Nice job. Do you, or anyone else, know if the original '76 CJ7 Dash Panel came with the speaker cutouts on both sides and if there was an option for the tach and clock?
I am restoring mine and the dash panel was chopped open at the radio area for a newer radio and as long as I was going to replace it figure I would add the tach, and second speaker. Bukt I don't want to add them if they were not an original option.
Thanks for help
onetouchdesign is offline
post #324 of 343 Old 12-02-2015, 09:45 AM Thread Starter
keith460
keith460's Avatar
Not for 1976. Only one speaker on passenger side was there up until about 1980 I think. Then two speakers became the standard.
Clock and tach only were standard on Laredo, Golden Eagle, Limited and Jamboree. All other models it's an option.
1984 CJ-7 Renegade
post #325 of 343 Old 12-02-2015, 11:16 AM
onetouchdesign
1976 CJ7
That what I figured out about the speakers. Wikipedia says there was a Golden Eagle model in 76 but I can't find it anywhere else. Do you know if they made a Golden Eagle
in '76?
I am finding a few things that were different in 76 & 77 versus other years. Do you know if the cables are drastically different sizes on 78-86 versus 76&77?
You are a wealth of knowledge that is gratefully appreciated.
post #326 of 343 Old 05-08-2016, 11:25 PM
regerman
I need to replace the speakers and temp gauge in my 1984 CJ7......my question to all of you knowledgeable people is....do I need to remover the steering column to have enough clearance to get the dash panel far enough out from the tub to access the speakers? I may try to replace the speedometer head while I am in there because the temp gauge has died. Is removing the steering column bezels enough?
Any guidance you can provide will be greatly appreciated.
regerman is offline
post #327 of 343 Old 05-09-2016, 06:35 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I replaced my front speakers without moving the dash. It was tight, but doable.
i can't say on the temp gauge, however, as my original still works.
Matt
Matt1981CJ7 is offline
post #328 of 343 Old 05-09-2016, 09:12 AM
wm69
You can remove/ replace the speakers and the speedometer without removing the dash. Not easy, but it's doable.
wm69 is offline
post #329 of 343 Old 05-09-2016, 11:22 AM
acgcoug
acgcoug's Avatar
1979 CJ5
My '79 has a single speaker, and the powerhouse, original AM only radio. I was able to replace my speaker without removing the dash.
_________________________
Adam's 1979 CJ5 Frame-up build:
acgcoug is offline
post #330 of 343 Old 11-28-2016, 09:21 PM
Hankey
1979 CJ5
Awesome wright up !!!! Thank you Kieth
Hankey is offline
cj2 restoration mxer Jeep CJ Forum 1 01-20-2011 09:41 PM
dash pad restoration help Baloo Jeep CJ Forum 10 01-08-2011 02:58 PM
'54 CJ-3B Restoration Mayfair_Jeeper Jeep CJ Forum 9 02-24-2008 02:33 PM
Best way to start a classic restoration? 85 Srambler original owner - no engine SomerJeep Jeep CJ Forum 7 06-11-2007 08:51 AM
78' CJ Restoration w/ 87' YJ tub Vidman35 Jeep CJ Forum 3 03-29-2005 11:57 AM
