CJ Dash Restoration.... that classic look! - Page 13 - JeepForum.com
 8Likes
post #181 of 343 Old 04-21-2011, 04:48 AM Thread Starter
keith460
keith460's Avatar
Originally Posted by jorns View Post
I also have the 4x??W with fader and so.
But the printcard looks a lot different from yours.
Any suggestion where to do the hook up the 3,5" jack?
My Jeep FM/AM radio is model 5751145
BR/Jorns
Can you post a higher resolution picture using Macro feature without using the camera flash of the printcard? Your radio just has a newer circuit board then mine did but the layout will be the same.
1984 CJ-7 Renegade
keith460 is offline
post #182 of 343 Old 04-21-2011, 10:08 AM
jorns
Of course. I disabled the flash, but macro future i dont have i think. Used two cameas.
All of them are located at my picasaspace. Note, some of the pictures are also from your HowTo.
https://picasaweb.google.com/skaarer/AMFMRadio#
1986 Jeep Cj7, 258CID, Dana300/30/44, Automatic, frame off 2010/11.
jorns is offline
post #183 of 343 Old 04-21-2011, 02:42 PM
justjeeps
Mounted the aux jack for the radio as I found a spare Jeep CJ cigarette lighter I had laying around and used the plastic bracket to hold the jack in place. All I needed to buy was a simple 18 1" plastic snap in plug and drill a 1/4" hole in the center for the jack.
Came out way better then I thought as it looks OEM and modernizes the original Jeep radio into the 21st century.
Great idea!
justjeeps is offline
post #184 of 343 Old 04-22-2011, 08:11 PM Thread Starter
keith460
keith460's Avatar
I downloaded some of your pictures and will try to determine what solder traces need to be cut and where the wires get soldered to. I use to know of a website that had Motorola wiring diagrams for the radios but for the life of me, I can't find it now. It will be the same for you radio as it was for mine. Motorola just modernized the board manufacturing process or used another source that's all.
1984 CJ-7 Renegade
keith460 is offline
post #185 of 343 Old 04-24-2011, 11:44 AM
jorns
Great.
I also found this one from the amcforum.
Is this helpfull?
http://theamcforum.com/forum/mp3-pla...opic16338.html
Is the signal that comes from the source volumeregulated before the amplifier? I thought the signal where amplified and then volumeregulated.
jorns is offline
post #186 of 343 Old 04-28-2011, 04:06 PM
jorns
I managed to add an AUX jack to my Jeep radio. It was quite diffrent than your Keith. But easier after i figured it out.
I just had to cut to wires and solder each of the ends on to the AUX jack.
Works great.
Thans for tips about this hack:
Note, as stated in the picture, this goes for only Jeep FM/AM Radio model: 5751145. I have no idea if this will work with simular radios.
jorns is offline
post #187 of 343 Old 04-28-2011, 04:20 PM Thread Starter
keith460
keith460's Avatar
I'm glad you found it as it was to hard to determine what wires needed to be cut without the actual circuit board in my hand to examine closely. It is definitely a great hack for the simple am/fm factory radio and you should post what wires and closeup shots of your finished work as other Jeeps are sure to have your radio with a more updated circuit board layout then mine was.
Enjoy your new found sounds in otherwise just another plain old radio that only received whatever was being broadcast on the airways. It is great to do that and cost next to nothing also.
1984 CJ-7 Renegade
keith460 is offline
post #188 of 343 Old 05-01-2011, 05:43 AM
jorns
Adding AUX to Jeep FM radio model: 5751145
Hi, here i s a guide to add AUX input for Jeep FM/AM radio model 5751145.
It will work like Keith has explained. When connection the iPod/mp3 it will bypass the radiosignal and send your iPod music to the speaker.
1) This is the factory layout. It has a brown and a green wire solder on the top of the printcard. Both of them needs to be either cutted or removed (as i did) and route to the radioshack 3,5" input jack.
2) In this picture i have unslodered the green and the brown wire and replaced it with 4 single wires. I used CAT 5e UTP cable (multicore, not single core) for the installation.
As pics shows the white/green and white/brown wire is soldered to the radio source signal side (point 3 and 4 on the radioshack input jack). And brown and green wire to the output side on the radioshack input jack.
3) This pictures shows the solder points of the backside of the printcard. You have to solder the 4 wires on the backside.
4) AFter soldering i i drilled a 6mm hole in the chassis to have the input jack installed at the chassis. I might be a little hazzle to connect it when driving but, i think i am going to add a input jack also in the center console so for me this the way to do it.
5) This is how I soldered the brown and green pair of wires to the radioshack input jack. Also notice that pin 1 must be grounded. Either solder it to the chassis or as i did to a ground point on the printcard.
  • 1. Black for ground.
    2. Green wire
    3. Green/White wire
    4. Brown/white wire
    5. Brown wire
6) Installation done.
7) Video of how it works.
jorns is offline
post #189 of 343 Old 05-01-2011, 05:20 PM Thread Starter
keith460
keith460's Avatar
Here's a video of the auxiliary jack being used through the radio using Pandora on my iPhone. Works every time!
Click on the picture to view the video:
1984 CJ-7 Renegade
keith460 is offline
post #190 of 343 Old 05-23-2011, 09:34 AM Thread Starter
keith460
keith460's Avatar
Found a good way to hold the iPhone while driving and listening to Pandora plus there is also a microphone for calls. Went to Best Buys and bought a cigarette lighter charger that holds the phone in place while charging. Cost about $50.00 and does not sag while driving around in a bouncy Jeep CJ.
1984 CJ-7 Renegade
keith460 is offline
post #191 of 343 Old 05-23-2011, 11:34 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Is that an Otter cover for the iPhone?
I hope so, I'm looking for a holder that will fit over my case so I can put it in any jeep I'm currently driving.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #192 of 343 Old 05-23-2011, 11:56 AM Thread Starter
keith460
keith460's Avatar
Dumb a** me forgot to name the manufacture of the device in the post.
It's made by Griffin Technology and is new according to their website and it fits all 3G, 4G iPhone even with a cover on.
Website URL: https://store.griffintechnology.com/...-aux-handsfree
1984 CJ-7 Renegade
keith460 is offline
post #193 of 343 Old 05-23-2011, 12:05 PM
John Strenk
1976 CJ5
Thanks, found it, but I wonder why your link takes me to http:\\www,fyurl,com???
I had to copy your link and paste it in my browser.
post #194 of 343 Old 05-24-2011, 02:21 AM
L78THUMPER
2007 MK Compass
here's mine
L78THUMPER is offline
post #195 of 343 Old 05-24-2011, 12:22 PM
red mistress
1983 CJ8
OEM Jeep radio's
Great write-up on dash restore. All 3 of my low mile CJ's have veins in paint from sheet metal screws.
I just found a 82 Oriental Scrambler all origional execpt radio was swapped out...fortunately dash was not cut.
Going to install this AM/FM model 5751145 and wish.....
there was a way to stream music from iPod like bluetooth.
(no wires)
Something like this work? http://www.1800mobiles.com/parrotbluetooth.html
I also have these NOS AM radio's for the Gladiator & Jeepster Convertible to modify.
67 Gladiator 15K AMC327 PTO Ramsey D44, D60 69 Jeepster deluxe Convertible Power 82 CJ-8 75K Renegade all original 83 CJ-8 50K 401 MPFI ARB60's front & rear winch 38" 84 CJ-7 38K Garnet interior, Jeep SE 8274, 8" x 33" 87 J20 36K Jeep SE Hidden winch, boat rack, 35" 2006 LJ Rubicon 3K
red mistress is offline
cj2 restoration mxer Jeep CJ Forum 1 01-20-2011 10:41 PM
dash pad restoration help Baloo Jeep CJ Forum 10 01-08-2011 03:58 PM
'54 CJ-3B Restoration Mayfair_Jeeper Jeep CJ Forum 9 02-24-2008 03:33 PM
Best way to start a classic restoration? 85 Srambler original owner - no engine SomerJeep Jeep CJ Forum 7 06-11-2007 09:51 AM
78' CJ Restoration w/ 87' YJ tub Vidman35 Jeep CJ Forum 3 03-29-2005 12:57 PM
