CJ cowl to windshield frame seal - Page 2 - JeepForum.com
 8Likes
post #16 of 22 Old 06-16-2021, 06:43 AM
orange150
1982 CJ8
I can't believe this got brought up! I emailed Steele Rubber to see if they could produce GOOD cowl seals, this was their reply to me:
I will pass this information to the parts team for review. Do you have an original part in case they want to use this as a pattern ?
Does anyone have any original specs or anything of this seal?
'82 CJ-8
258/AX15/D300
OME YJ 2.5"/31s
D30/D44/3.73s/Truetracs
orange150 is offline
post #17 of 22 Old 06-16-2021, 06:47 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I used this stuff to secure mine. It worked well.
Matt
Matt1981CJ7 is offline
post #18 of 22 Old 06-16-2021, 06:53 AM
robblue6412
robblue6412's Avatar
1980 CJ7
I don't have original specs, and I think that seems like an odd request from them. Almost sounds like a "go away" response.
I used the Fairchild seal (https://www.quadratec.com/products/22501_11.htm) and it fit very well. I've had great success with Fairchild seals - also used one for my windshield. They are good quality and have fit perfectly each time.
Rob
1980 CJ7 304/4sp
robblue6412 is online now
post #19 of 22 Old 06-16-2021, 07:17 AM
robblue6412
1980 CJ7
Thanks Matt, I ordered some up!
Rob
1980 CJ7 304/4sp
post #20 of 22 Old 06-16-2021, 10:34 AM
bob4703
1974 CJ5
That's where I got my last one. https://www.steelerubber.com/windshi...rip-70-3004-42
Of course if you have anything newer than a 75 you are SOL.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #21 of 22 Old 06-16-2021, 11:10 AM
gutthans
gutthans's Avatar
Did you clean the inside face of the rubber with acetone first??? The rubber is coated from the manufacturer with a teflon-based mold release and this will not bond well (obviously). You'll need a new strip of two-sided because the TFE will transfer onto it rendering that side not so sticky now.
gutthans is offline
post #22 of 22 Old 09-07-2021, 04:09 PM
robblue6412
1980 CJ7
Thanks - I didn't know this! So far as time has gone on the seal is sticking better to the tape. Next time I will keep this in mind.
Rob
1980 CJ7 304/4sp
