CJ-7 258 Oil Type - JeepForum.com
 3Likes
  • 2 Post By Matt1981CJ7
  • 1 Post By jeepdaddy2000
post #1 of 11 Old 02-10-2020, 08:33 AM Thread Starter
ejjaeke
1973 CJ5
CJ-7 258 Oil Type
Just picked up a 1979 CJ-7 258. I have read all the threads about oil types, but I can't find any thread newer than 2011. Does anyone have any updated advice on the best motor oil type to use? Still best to use a diesel rated oil for higher zinc levels, or is there a better method? If I missed a thread that is more recent, I apologize. Looking forward to getting into this project!
ejjaeke is offline
post #2 of 11 Old 02-10-2020, 08:42 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
uptillnow and Deer-Slayer_5 like this.
Matt1981CJ7 is offline
post #3 of 11 Old 02-10-2020, 06:18 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
Welcome ejjaeke! There is a wealth of knowledge and information on these forums.
Might want to change the displacement of your engine in your profile from 268 to 258 - maybe it was bored over?
Well OK - I'll jump in. Heavy Duty Flame Suit On. I use the following oil & oil filter in my 1979 Jeep CJ5 304 V8 . . . . .
Valvoline VR1 10W-30 (Non-Synthetic). I change the oil with the oil filter twice a year. I put maybe 2,000 - 3,000 miles on my Jeep per year.
I purchase the oil and oil filter from Summit Racing.
https://www.valvoline.com/our-produc...vr1-racing-oil
https://www.summitracing.com/parts/vlv-vv205-6
https://www.summitracing.com/parts/wix-51258
NOTE: I DO NOT KNOW: If this oil and oil filter will work for your particular engine - How your Jeep is driven - Or the climate where you and your Jeep reside.
Just responding to your question. Maybe look at sites like https://www.bobistheoilguy.com/ for additional info. One again Welcome!
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is offline
post #4 of 11 Old 02-10-2020, 06:49 PM
only in a jeep cj
I use Valvoline 10w40 High Milage in all my CJs. Many years , no problems.
Now if you really want to stir the pot, ask everyone’s opinions on oil filters.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 2003 Inca Gold TJ Rubicon
2012 JKUR RHD
only in a jeep cj is offline
post #5 of 11 Old 02-10-2020, 07:12 PM
only in a jeep cj
Deleted double post
post #6 of 11 Old 02-10-2020, 08:16 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
I use ordinary 10w30, not synthetic. With the low miles i put on the oil will not break down for several years. I try for annual oil changes. These engines have been running on this stuff for near 40 years, enough said.
However I do add a can of Arbo engine oil treatment to keep the lifters quiet. No idea what is in it but would not be surprised to see zinc. It is also very cheap.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #7 of 11 Old 02-10-2020, 10:52 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I prefer a little thicker oil for older engines used in "normal" climates. Either 10-40 gas or 15-40 diesel oils are fine. The engines aren't sophisticated enough to require synthetic oils.
I run 15-40 Rotella changed every 5000 miles.
Rotella is also an acceptable oil for wet clutch applications in bikes and quads.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #8 of 11 Old 02-11-2020, 08:24 AM Thread Starter
ejjaeke
1973 CJ5
Great stuff, thanks everybody. I know it is a touchy subject, but your advice is similar to the stuff I saw on bobistheoilguy, and I appreciate it. Looking forward to getting this project going!
ejjaeke is offline
post #9 of 11 Old 02-20-2020, 08:13 AM
bicyclemonkey
I was told to use Valvoline VR1 20w-50 in my '67 Beetle, so I'm just going to put that in my 258 CJ-7 when I change the oil next month. I only put maybe 3000 miles tops each year on each of those vehicles so I just change the oil every spring.
bicyclemonkey is offline
post #10 of 11 Old 02-21-2020, 02:02 PM
hp_lovecraft
1981 CJ5
I use whatever 15w-40 diesel oil is on sale, and have for 15 years or so.
Its thicker, has more additives, and... oddly.. tends to be cheaper then normal engine oils.
I'll change it usually after I've burned off 10 quarts or so. Its pretty black at that point.
My bigger problem is I can't get most filters to fit. Years ago I buggered up the frame a bit, and most filters just don't fit at all. The purolator ones fit, but pretty much all other brands don't. Fram and Wix-based ones don't. Or maybe another brand? its a hassle, so I just always use purolators now.
hp_lovecraft is offline
post #11 of 11 Old 02-21-2020, 08:15 PM
jeepdaddy2000
1971 CJ5
Can't say as I agree with your maintenance schedule, but as for the oil filter issue:
https://www.summitracing.com/search/...elocation-kits
bob4703 likes this.
Thomas Payne
