CJ 6 Bolt Hub Bolt Size - JeepForum.com
 2Likes
  • 2 Post By CSP
post #1 of 7 Old 12-14-2019, 07:37 AM Thread Starter
GX310
GX310's Avatar
1982 CJ7
I am looking for the bolt size and thread for the bolts on the 6 bolt hubs. Are they the same as the 5? Gathering all of the parts to do the 6 bolt hub swap
GX310 is offline
post #2 of 7 Old 12-14-2019, 10:24 AM
only in a jeep cj
Yes, same as the 5 bolt hubs. I went with grade 8 that had a shoulder that ended just as it entered the hub. This way the lockout had the best shear load on the bolt. Blue lock tight or a thick lock washer help too. I’ve used stud kits on a few as well.
Depending on the year of the donor that you get the six bolt from, I only transferred the hub and the lockout over and everything else was the same. For those with stock rims, the later 5 bolt center cap will no longer fit.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 7 Old 12-14-2019, 05:41 PM
CSP
I happen to have one torn apart right now. They are 3/8"-16 by 1.5" long.
TerryHowe and OrangeCJ-5 like this.
CSP is offline
post #4 of 7 Old 12-14-2019, 10:31 PM
Spieg8
1984 CJ8
Yep, all the same thread pattern.
I like to use studs rather than bolts.
It's not the Voltage, but the Amperage that will kill you.
Spieg8 is offline
post #5 of 7 Old 12-15-2019, 12:36 PM Thread Starter
GX310
GX310's Avatar
1982 CJ7
Awesome thank you all. I purchased some new Warn 9062 Premium hubs but the hub portion that houses the Warn hub I purchased was used and the threads were really dirty so I am going to purchase a tap to clean out the threads and new bolts or studs and put it all together this weekend!
GX310 is offline
post #6 of 7 Old 12-16-2019, 06:02 AM
oldschool74cj5
hello
spieg8 did you get the warn stud kit or did you use 2" grade 8 studs? just curious cause looking at changing mine from bolts to studs.
oldschool
oldschool74cj5 is offline
post #7 of 7 Old 12-16-2019, 01:26 PM
Spieg8
1984 CJ8
I used Grade8 manifold studs from the LHS with red lock-tite. I got them long enough to bottom out in the holes (more thread engagement is good) and trimmed the ends to proper length for the hub/nuts/washers.
Spieg8 is offline
