CJ 5 Camber issues - JeepForum.com
 2Likes
  • 2 Post By Fourtrail
post #1 of 6 Old 06-28-2017, 09:39 PM Thread Starter
zippy2099
Cj CJ 5 Camber issues
Hello,
I have a 1975 CJ 5. It has a lift kit on it and I'm having issues with the camber. I've got a buddy that has a 4x4 shop and he's having problems finding adjustable ball joints and shims to correct the issue. Anybody have an idea where I can find any. Everywhere he's tried he's told they're out of production. Help!!!
zippy2099 is offline
post #2 of 6 Old 06-29-2017, 02:31 PM
pedal2themetai
1956 CJ5
HI, Never heard of any adjustments in a Jeep front differential camber adjustable. its a solid front differential isn't it? I don't think there is any adjustment. might be bad barrens.
good luck
tim
pedal2themetai is offline
post #3 of 6 Old 06-29-2017, 02:49 PM
Fourtrail
1974 CJ6
Not too hard to find.
Adj upper ball joint insert
http://www.oreillyauto.com/site/c/se...CJ5&vi=1180639
Spindle shim
http://www.oreillyauto.com/site/c/se...Redirect=04120
rock auto also has a few different ball joint inserts and the spindle shims
http://www.rockauto.com/en/catalog/j...+bushing,13508
http://www.rockauto.com/en/catalog/j...acer+kit,13507
HoDad and pedal2themetai like this.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #4 of 6 Old 06-29-2017, 04:44 PM
HoDad
1981 CJ5
I have the 2 piece Moog from OReilly, works great.
HoDad is offline
post #5 of 6 Old 07-01-2017, 09:37 AM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
I tried the adjustables early on and I was unsatisfied with them so I ended up taking the rig to a frame alignment shop where they properly shimmed the knuckles. It's a bit more costly but if you get it done right it will bear dividends on how will it handles on the road.
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
post #6 of 6 Old 07-02-2017, 12:04 AM
80cj
80cj's Avatar
1980 CJ5
It is OK to use shims on Jeeps that have the disc brake caliper bracket secured with the spindle studs. On later Jeeps that have the caliper bracket bolted to the back of steering knuckle, you should use an offset ball joint to adjust camber. The reason being that using shims on the later type will cause the rotor to run at a different angle than the caliper.
80cj is offline
adjustable , ball joint , camber , cj5 , shims
