carter popping after rebuild smells rich - JeepForum.com
post #1 of 13 Old 04-17-2009, 07:09 PM Thread Starter
keithf
1983 CJ7
Hey all,
I just finished a rebuilt kit for my carter bbd now it is popping or backfiring and smells like fuel. The only thing i did besides clean and replace gaskets was to drill the idle tubes out with 1/32" bit and adjust the float a little. it is set at 1/4".
also the idle mix screws were at 3 turns and 5 turns. should they be the same?
I put something back wrong. any ideas what?
thanks
keith
keithf is offline
post #2 of 13 Old 04-18-2009, 05:01 AM
Mike Romain
Did you get the two ball bearing check valves back in the right holes? They are different sizes.
Your mix screws need to be adjusted for best lean idle and yes, they should be the same.
What about the computer controls like the stepper motor? What did you do with that?
Mike
Mike Romain is offline
post #3 of 13 Old 04-18-2009, 06:28 AM Thread Starter
keithf
1983 CJ7
i got the balls in correctly. the smaller one towards the back. i set the idle mix screws both at 3 turns out. i forgot to mention that the carb is off an 81 so no computer control(BTW can i still nutter this one by connecting the distributor to the ignition box).
it seams like it's flooding b/c the gasket above the fuel inlet is leaking but i put a straight edge across, held the float up and it is right on 1/4. that is really the only thing i changed except the idle tubes.
thanks for helping.
keith
keithf is offline
post #4 of 13 Old 04-18-2009, 06:56 AM
Mike Romain
thanks for helping.
keith
Leaking out the top means the float needle and seat are dirty or the float is too high. The kit came with a new needle and seat so maybe some junk from that piece of U shaped gas line just in front of the carb got in it. That line should get it's own clean and you need two wrenches to install it or the float setting goes way off.
The one wrench holds the seat of the float needle in one place and the second wrench screws the gas line into it.
Mike
post #5 of 13 Old 04-18-2009, 07:28 AM Thread Starter
keithf
1983 CJ7
i just lowered the float a little to where it was before i adjusted it. still getting the popping and bad idle. i'll check for trash in the seat next.
thanks
keith
keithf is offline
post #6 of 13 Old 04-18-2009, 12:42 PM Thread Starter
keithf
1983 CJ7
the seat was clean. it seams like the engine is knocking a little too. any other ideas or should i just take it all back apart and try again with the rebuild?
keith
keithf is offline
post #7 of 13 Old 04-18-2009, 12:44 PM
Mike Romain
keith
I would adjust the mix correctly first. Do you know how to set those mix screws?
Mike
post #8 of 13 Old 04-18-2009, 12:53 PM Thread Starter
keithf
1983 CJ7
no i don't have any gauges though.
keithf is offline
post #9 of 13 Old 04-18-2009, 01:19 PM
Mike Romain
It's easier to do with an rpm gauge, some timing lights even have those, but you can do it by ear.
When I set the carb, I carefully turn each screw all the way in counting the turns so I know where they started. I then back them off full rich or 5 turns out each. I get it warmed up and adjust the idle speed expecting to have to adjust the idle speed several more times to keep it at 700 rpm.
I then start by turning each screw in 1/4 turn and give it a rev or two to set. Then I listen and do it again, 1/4 turn and a couple revs. The idle speed will change as I do this, so once it is off 50 rpm, I reset it.
Eventually I will come to a point where that 1/4 turn makes the engine start to stumble. I then back it off 1/4 turn for the 'best lean' idle that will just purr or 1/8 turn with a slight rumble still for the emissions sniffer (ASM2525 dyno) and get the idle speed dialed in at 700 or nice and smooth and low.
Mike
post #10 of 13 Old 04-18-2009, 01:24 PM Thread Starter
keithf
1983 CJ7
thanks mike,
I'll go try it now.
keithf is offline
post #11 of 13 Old 04-18-2009, 01:41 PM Thread Starter
keithf
1983 CJ7
i backed them out and turned them back in about a turn and a half before it quit. the idle did not change, it was stumbling the whole time. the exhaust is real dark and it is turning my driveway black. the popping is very constant about every 2 seconds at idle. speeds up when you upon the throttle.
keithf is offline
post #12 of 13 Old 04-18-2009, 01:47 PM
Mike Romain
Something inside is wrong then it would seem...
Mike
post #13 of 13 Old 04-18-2009, 01:56 PM Thread Starter
keithf
1983 CJ7
thanks i'll break it down and see what i did wrong.
thanks again
keithf is offline
Carter YF experts, I'm running way too rich SuB8HaVeN Jeep CJ Forum 18 08-21-2013 07:31 PM
carter yf seems to be running rich. mcurcio1989 Jeep CJ Forum 13 09-01-2010 01:58 PM
Idle on Carter is Rich desert_driller Jeep CJ Forum 0 01-23-2010 02:37 PM
Carter BBD too rich... how to lean? HighFive Jeep CJ Forum 12 01-16-2010 10:35 AM
Rich exhaust/popping noises???? Skinnyfeet Jeep CJ Forum 3 10-11-2009 08:01 PM
