Carter BBD Choke Adjustment - JeepForum.com
post #1 of 7 Old 12-18-2019, 09:20 PM Thread Starter
258
Cj Carter BBD Choke Adjustment
Folks, my Carter 2bbl BBD carb is not idling down after warm up. I am guessing the colder weather we are having may have something to do with it? Otherwise, it runs fine!
So, I need to adjust the electric choke so that it drops the idle down after I pump the pedal; after about 1 minute. My question is: which direction do I turn it? Is it counter clock-wise or clock-wise? Again, Jeep starts fine, goes up to 1250-1400 rpm while warming up and then I usually give it a pedal pump to drop the idle to 800 rpm. It is not doing this. It is staying on the high idle side way too long. I literally have to take the pedal to the metal a few times to get a reaction or open the hood and manually adjust the idle notch. I just want to give it a very light adjustment.
258 is offline
post #2 of 7 Old 12-18-2019, 09:27 PM
Fourtrail
1974 CJ6
The choke heater coil cap should be marked with a + and - turn more to the - side for a quicker warmup high idle pulloff.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #3 of 7 Old 12-19-2019, 04:47 AM
John Strenk
John Strenk's Avatar
1976 CJ5
also make sure the linkage is clean. do not oil or grease anything on the linkage.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is online now
post #4 of 7 Old 12-19-2019, 08:43 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Also make sure the choke is getting power when the engine is running.
Matt
Matt1981CJ7 is offline
post #5 of 7 Old 12-19-2019, 11:00 AM
Boojo35
1987 YJ Wrangler
Matt
This....
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #6 of 7 Old 12-19-2019, 11:40 AM
John Strenk
1976 CJ5
Matt
And grounded!
The clamping ring around the Choke housing can get rusty causing a bad ground connection for the heater.
There is a metal strip on the choke housing that makes contact with the clamping ring that needs good electrical connection.
A good test is if you put your volt meter on either of those two rivets in the red square and see 12 volts, it's not grounded.
Clean up both the ring and the metal strips.
Also if you have to remove the ring, There might be a couple of rivets that can be pulled out and self tapping screws put in.
If you are not getting 12 volts to the chousing check your BU fuse first. then check you oil pressure switch.
post #7 of 7 Old 12-20-2019, 12:07 AM Thread Starter
258
Ok guys, got it adjusted and all cleaned up. (Carb/choke) It was difficult to loosen those 3 screws on the choke because of the tight fit. Also, the throttle plate was open more then I expected it to be so that was adjusted. It starts right up and idled down after about a minute and a half. PERFECT! So on the high side 1250-1300 rpm, at idle; 800 rpm.
258 is offline
