Carrier Parts - JeepForum.com
post #1 of 3 Old 09-16-2020, 08:12 PM Thread Starter
Monastero
Carrier Parts
I have a CJ7 original spare tire carrier. It has the two small rubber bumpers that connect the carrier to the tailgate,. They are underneath a larger diameter threaded hole. Probably 1/2” or so. Is this larger hole for a stud of some sort, to keep pressure on the spare and prevent it from movement etc? If so, where can I get this part? Im sure I can use a bolt if not possible to get the part anymore.
Monastero is offline
post #2 of 3 Old 09-17-2020, 02:32 PM
only in a jeep cj
Yes, it’s a carriage bolt with a larger than normal head that rest against the tire.
If a wider tire is used, the bolt may need to be shortened so it doesn’t hit the body when the gate is closed.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 2003 Inca Gold TJ Rubicon
2012 JKUR RHD
only in a jeep cj is offline
post #3 of 3 Old 09-17-2020, 04:37 PM Thread Starter
Monastero
Ok, thanks.
