Can't find air cleaner for Carter Carburetor - JeepForum.com
 2Likes
  • 2 Post By Hurricane4
post #1 of 13 Old 02-18-2020, 03:27 PM Thread Starter
jbdinvt
1982 CJ7
New to Jeeps - recently purchased an '82 CJ7 for my 13 yr old son and I to work on together (he's teaching me!)
There was no air cleaner on the carb when we bought it and the PO said he recently installed the carb, which I believe is a Carter T2-8383S. I can't find an air filter assembly or a bracket that will attach the air cleaner assembly to the carb. Maybe that's why the PO never put one on. Picture of the carburetor attached.
jbdinvt is offline
post #2 of 13 Old 02-18-2020, 04:24 PM
Jon In Tucson
Jon In Tucson's Avatar
1983 CJ5
I had a similar situation with the BBD carburetor like yours. I went to O'Reilly's with the diameter of the carburetor opening. I bought an Edelbrock aftermarket air cleaner with different mounting bases. It uses the same filter element as stock, and fits without interference to the power brake booster. Also, it has a chrome cover which guarantees a minimun increase of 10 HP. Lol.
Jon In Tucson.
Sent from my SM-G930V using Tapatalk
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline
post #3 of 13 Old 02-18-2020, 05:02 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
I think you are missing the sort of U-Shaped rod with a center threaded hold down / wing nut.
Found some photos on eBay - This might be your carb:
https://www.ebay.com/itm/Jeep-CJ-2-b...kAAOSw6SNePfL3
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is offline
post #4 of 13 Old 02-18-2020, 05:09 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
Here you go -
https://www.ebay.com/itm/Carburetor-...8AAOSwcuNeKFJ9
Winston Churchill
post #5 of 13 Old 02-18-2020, 11:03 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
I have a generic go faster chrome one, about $10. I would love to have an original Thermostatic Air Cleaner, they are so much better. Fixing method as above, you could make one with stiff wire and nut and bolt.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 13 Old 02-19-2020, 11:32 AM Thread Starter
jbdinvt
1982 CJ7
Thanks! Yes, that is the bracket I've been looking for, but haven't been able to find. Much appreciated!
jbdinvt is offline
post #7 of 13 Old 02-19-2020, 01:04 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
You’re welcome. Checked eBay and saw that part was sold. Did you purchase it? Seller is great. Have dealt with him on several Jeep related purchases.
Winston Churchill
post #8 of 13 Old 02-19-2020, 01:08 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Don't forget early YJ aircleaners also fit
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #9 of 13 Old 02-19-2020, 02:11 PM
shadoow
John, which years are the 'early years' ? I'm not that familiar w/YJ's
shadoow is offline
post #10 of 13 Old 02-19-2020, 03:16 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
Jeep Wrangler YJ (square headlights) production years ran from 1987 to 1995. In the ‘87 through ‘90 model years the 258 six cylinder was an option.
Winston Churchill
post #11 of 13 Old 02-19-2020, 04:14 PM
shadoow
Thanks!
shadoow is offline
post #12 of 13 Old 02-25-2020, 02:22 PM Thread Starter
jbdinvt
1982 CJ7
Yes, I did purchase that one and it arrived yesterday! Thanks for the help. This forum is a GREAT resource.
jbdinvt is offline
post #13 of 13 Old 02-25-2020, 09:44 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
FYI: I run a factory air cleaner with the "accordion snorkel" to the inside of the grill on my '79 CJ5 304 V8.
Not a fan of the open element air cleaners. They just pull hot air from around the engine.
Glad you were able to get that part. Here is a list of web sites in addition to eBay you may find useful:
http://forums.off-road.com/jeep-short-wheelbase/
http://shop.advanceautoparts.com/
http://staceydavid.com/
http://vintagevibes.net/jeepcj.htm
http://www.4wd.com/
http://www.allstate4wd.com/
http://www.allthingsjeep.com/
http://www.americanpartsdepot.com/index.htm
http://www.autozone.com/autozone/
http://www.bantamjeepfestival.com/
http://www.classicinlines.com/DUI_install.asp
http://www.cliffordperformance.net/index.html
http://www.collinsbrosjeep.com/main.htm
http://www.daveysjeeps.com/index.html
http://www.delorean.com/index.html
http://www.earlycj5.com/
http://www.edelbrock.com/
http://www.gemini-sales.com/
http://www.grimmjeeper.com/gears.html
http://www.jcwhitney.com/
http://www.jeep4x4center.com/
http://www.jeep-cj.com/
https://www.jeepforum.com/forum/f8/
http://www.junkyardgenius.com/toc.html
http://www.moabjeeper.com/
http://www.novak-adapt.com/
http://www.oconeeoffroad.com/servlet/StoreFront
http://www.offroaders.com/tech/jeep/main.htm
http://www.performancedistributors.com/index.html
http://www.pirate4x4.com/forum/index.php
http://www.quadratec.com/
http://www.ruffstuffspecialties.com/catalog/
http://www.solargraphicsusa.com/page...terndecals.htm
http://www.speedwaymotors.com/
http://www.summitracing.com/
http://www.tellico4x4.com/
http://www.throttledownkustoms.com/index.html
http://www.tntcustoms.com/
https://www.amclives.com/
https://www.holley.com/
https://www.jeepsunlimited.net/
https://www.jwjeep.com/
https://www.napaonline.com/
https://www.rudys-cjs.com/
https://www.vintagejeepparts.com/
https://deadjeep.com/
https://jeeprepublic.com/
https://midwestjeepwillys.com/
https://performancedistributors.com/
https://somarmotor.com/
https://stores.partsdude4x4.net/
www.jeeptech.com
http://mtscompany.com/index.htm
keith460 and BagusJeep like this.
Winston Churchill
