Cable Clutch Conversion? - JeepForum.com
post #1 of 8 Old 02-19-2015, 12:15 AM Thread Starter
RLPII
1974 CJ5
I am considering converting my 74 CJ5 (AMC 360) to a cable clutch to eliminate the clutch linkage binding up when the frame flexes. Does any one have a parts list or is there a kit available to make this conversion?
Any help would be appreciated.....TIA
RLPII is offline
post #2 of 8 Old 02-19-2015, 08:33 AM
my73CJ
1973 CJ5
When I bought my 73 it had a cable and to be honest it sucked, it broke and was lucky enough to fix on the trail, then ended up having to replace it with one I had Fleetpride custom make and that one only lasted 9 months and that one broke, they were both extreme duty cables, so I ended up making up my own linkage, been fine now for 4-5 years, I know I wouldn't go back. I have never had a flexing / clutch issue with my linkage, but that is just me.
my73CJ is offline
post #3 of 8 Old 02-19-2015, 09:18 AM Thread Starter
RLPII
1974 CJ5
The more I look into the cable idea the less I like it.....lots of breakage. So, how about the hydraulic clutch set ups, any thoughts on that? Does anyone make a "Kit" to confront the linkage to hydraulics?
RLPII is offline
post #4 of 8 Old 02-19-2015, 09:19 AM Thread Starter
RLPII
1974 CJ5
should be "convert the linkage"
RLPII is offline
post #5 of 8 Old 02-19-2015, 09:30 AM
Cutlass327
Cutlass327's Avatar
1930 CJ2
The hydraulic system is standard on the 4 cyl 80's CJ. There is a lot of info on Google for that, I used a few pages from a coupe search results when I converted mine. I used the stock replacement master cyl, but used adapters and some braided stainless line instead of the stock line. The slave for mine is a Novak part, but I am using a Ford 302 bellhousing, where on the AMC I believe you can just adapt the CJ's slave to the 258/304 housing. I also sourced a YJ Clutch pedal, as the mechanical vs hydraulic pedal is different. The mechanical pedal can be adapted, but I figured I'd go the easy route and just swap pedals. You don't have to change out the whole pedal ***'y, either. A snapring on the shaft and the pedals slide off. I drilled/tapped my 'new' one for a grease fitting while it was off, as I hear the bushings wear over time and mine were still good - I figured a shot of grease now and then wouldn't hurt. I will say, my mechanical had needle bearings instead of bushings, don't know if that was an original thing or not.
Rick
1978 CJ5 5.0HO/T177/D300 TerraLow 4:1 kit, '86 D30/D44 3.54 WT axles w/Aussies, 'glass body, 33x12.5 ProComp A/T, TDK galv'd frame, 2.5 OME YJ lift - DD and weekend toy
Cutlass327 is offline
post #6 of 8 Old 02-19-2015, 11:00 AM
Erik719
Erik719's Avatar
1983 CJ7
I would do the hydraulic option if you're going to do a conversion.
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline
post #7 of 8 Old 02-19-2015, 04:35 PM
Cutlass327
Cutlass327's Avatar
1930 CJ2
RLPII, I just noticed that your username looked familiar - my initials except for the 'II'.
Rick
post #8 of 8 Old 02-20-2015, 12:28 AM Thread Starter
RLPII
1974 CJ5
Thanks for all the info and comments.....sounds like the hydraulic is the way to go. Will need to do some research so might be awhile!
Bob
RLPII is offline
