Bypass hose??? - JeepForum.com
post #1 of 9 Old 09-19-2019, 06:25 PM Thread Starter
Ermbe5
Bypass hose???
I have/had a hose on my 1982 CJ7 4.2l that burst and I’m having a hard time finding a replacement. The hose runs from my thermostat housing to the intake manifold. The hose fitting at the t-stat housing is for a 7/8 inch hose (I tried 3/4” and it doesn’t fit) and the hose fitting at the intake manifold fits a 5/8 inch hose. I believe this is for a bypass hose. You can’t look it up by application, no one seems to carry 7/8” hose so I ordered online but now I can’t find a fitting to go on the intake to fit the 7/8” hose. What have you all done to replace this hose??
Ermbe5 is offline
post #2 of 9 Old 09-19-2019, 06:42 PM
Axhammer
Axhammer's Avatar
Is this the hose you are talking about? The one that is spliced in the middle? It looks like mine uses two different size hoses spliced in the middle. When I first got this Jeep is was leaking a little, I think the bigger size hose is just clamped to the smaller splice, but after being tightened it quit leaking so I havent given it much thought since.
Im going to drain the coolant so I can remove my heater box tomorrow, and replace my blower motor with the YJ style fan motor. Ill check it out closer tomorrow and let you know for sure.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is offline
post #3 of 9 Old 09-19-2019, 06:49 PM Thread Starter
Ermbe5
Yes that’s the one! Sounds like I’ll need to splice and reduce it down. Thanks! And yea I’d be happy to hear what you find tomorrow
Ermbe5 is offline
post #4 of 9 Old 09-19-2019, 08:34 PM
Hoover7
Hoover7's Avatar
This thread may also be of value for the heater hose question.
https://www.jeepforum.com/forum/f8/h...-size-3987737/
Hoov
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
post #5 of 9 Old 09-19-2019, 08:37 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
it is described in the parts book as Hose, Bulk, 1 foot. Not helpful, but that is why you cannot find it on line
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 9 Old 09-20-2019, 08:53 AM Thread Starter
Ermbe5
Thanks for the information, it was very helpful. I just bought some bulk 7/8” hose online. Funny that everything thing I’ve read says it’s a 3/4 to 5/8 hose. I tried using 3/4” and it did fit. Oh well what ever I can make work, works. Thanks for the info and help!
Ermbe5 is offline
post #7 of 9 Old 09-20-2019, 08:16 PM
Axhammer
Axhammer's Avatar
I took my bypass hose off, and disconnected each end from the 5/8 by 3/4 brass adapter in the middle. I wanted to confirm what I had and what I need to make it right. It had two hose clamps on the manifold end of the 5/8” hose, because it has leaked in the past, so my kid put a second clamp on it to get it to stop leaking. I had forgotten about the situation until reading this thread. Since I was taking the valve cover and heater box off today, I figured why no fix this bypass situation too. I’m not sure what I’ll put back on, but it will be new hose if nothing else. The 3/4 hose has a molded in curve, it’s not a straight section like the 5/8 hos end.
Axhammer is offline
post #8 of 9 Old 09-21-2019, 05:43 AM
keith460
keith460's Avatar
That hose is hard to find in stock molded size and length. I bough a NOS one from a Wrangler parts website in 2007 and it was the last one they had.
Guys have success using and trimming these hoses that can be used:
NAPA #NBH 10763
Gates #18078
Dayco #87305
Dayco #E80416
1984 CJ-7 Renegade
keith460 is offline
post #9 of 9 Old 09-21-2019, 07:07 AM
Axhammer
Axhammer's Avatar
My thoughts on this since the OEM style hose seems unobtainable. The 5/8 90 degree fitting on the aluminum manifold, uses pipe thread to attach to the manifold, it Looks like 3/8 PT to me, but when I tried to break torque to remove mine it was on the verge of breaking off or rounding, so I stopped. If a person were to remove this 90 degree 5/8 hose fitting, and replaced it with a 3/4 straight fitting, a single piece of 3/4 heater hose could be used, it would bend and take the big U shape just fine I believe. It would stick up higher, and look different, but it would be a repair unlikely to fail or leak. If a 3/4 heater hose with a ninety degree bend on one end, with the other end being straight were obtained and a 3/4 ninety degree installed on the manifold, it would look OEM. There are options, depending on what you want the end result to look like, and whether or not you have a good hydraulic hose business/store locally. A good hose store will have these basic fittings, making the rubber hose part of the deal easier.
Axhammer is offline
