brake pedal differences? - JeepForum.com
 5Likes
  • 2 Post By keith460
  • 1 Post By Delta0
  • 1 Post By fibersport
  • 1 Post By REDnBLUES
post #1 of 14 Old 09-12-2021, 05:59 AM Thread Starter
fibersport
When converting from manual brakes to a factory power brake system, is the same brake pedal used? I know when doing a similar swap on other vehicles, there is usually a different brake pedal because of the difference in force required to apply the brakes butI've never seen that mentioned in any jeep posts I've read.
1984 CJ7 Renegade
4.2 with 4 speed
researching other details!
fibersport is offline
post #2 of 14 Old 09-12-2021, 06:09 AM
keith460
keith460's Avatar
There is a different brake pedal used for power brakes vs manual brakes but I do not know what the difference is.
I converted to power brakes back in 1988 and only purchased new MC, MC brake lines, Booster, Booster brackets and a brand new factory Air Cleaner w/offset. Never knew about the different pedals back then and never had a problem with the original manual pedals I still use today.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 14 Old 09-12-2021, 06:10 AM
Delta0
The only difference I've met has been pushrod length Fiber.
pedal2themetai likes this.
Delta0 is offline
post #4 of 14 Old 09-12-2021, 08:01 PM Thread Starter
fibersport
Thanks for the replies, good to know.
1984 CJ7 Renegade
4.2 with 4 speed
post #5 of 14 Old 09-13-2021, 10:39 AM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
Easy fix. Get one of these: https://www.summitracing.com/parts/SUM-760125
1980 Jeep CJ5 Renegade
CJ5_Fan is offline
post #6 of 14 Old 09-14-2021, 04:25 PM
CSP
It depends on the year of your CJ, because some use the same part number whether power or manual.
CSP is offline
post #7 of 14 Old 09-14-2021, 09:33 PM Thread Starter
fibersport
I briefly looked it up in the parts manual and it looks like there are indeed two different ones, I would have to check the year to be sure though. thanks for the tip
1984 CJ7 Renegade
4.2 with 4 speed
post #8 of 14 Old 09-15-2021, 10:01 AM
Delta0
Would fitting a remote servo make life simpler?
Delta0 is offline
post #9 of 14 Old 09-15-2021, 08:08 PM
pedal2themetai
1956 CJ5
HI Not sure but I think the pedal are only different if its a Automatic.. They usually make the automatic pedal longer so it is easier to access with the left foot..
good luck
tim
pedal2themetai is offline
post #10 of 14 Old 09-15-2021, 08:30 PM Thread Starter
fibersport
I think Keith460 answered it, there is a difference but it doesn't seem a major one. I currently have manual brakes, I also have an OEM booster, booster bracket and a master cylinder (which needs to be replaced). My concern was that the manual brake pedal would not fit, in Keith460's case it seems to be OK after all these years.
1984 CJ7 Renegade
4.2 with 4 speed
post #11 of 14 Old 09-16-2021, 10:10 AM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
When I converted my 1980 Cj5 with manual transmission from manual to power brakes my process was only to change out the manual MC assembly with a with a factory CJ booster and master cylinder assembly with bracket.. After I was done I had 2 issues. 1st the pedal height was not equal with the clutch pedal height. I resolved that by changing out the push rod with an adjustable version that allowed me to set the pedal height equal . The 2nd issue I had was that my motor did not have enough vacuum to properly operate the booster. The stock CJ booster requires 22HG to properly activate. Since my motor only put out 17HG I installed an inline vacuum booster that kicked me up to the required 22HG.. I have been running this setup for years with absolute zero issues. The only items I had to change was the booster assembly with bracket and the push rod. I'm not sure if an automatic Cj7 requires something different or or if the manual CJ assembly verse the auto CJ assembly would require the same approach.
CJ5_Fan is offline
post #12 of 14 Old 09-17-2021, 03:58 AM
keith460
keith460's Avatar
Hmm, don't seem to have that problem. If there is a difference in pedal height, its very subtle.
1984 CJ-7 Renegade
keith460 is offline
post #13 of 14 Old 09-17-2021, 08:01 AM
bob4703
1974 CJ5
Is the pedal for one with an A/T wider than a normal Jeep?
Paved roads are prime examples of government over spending!
bob4703 is offline
post #14 of 14 Old 09-18-2021, 08:50 PM
REDnBLUES
REDnBLUES's Avatar
1977 CJ7
Yes. It's roughly twice the size of the standard shift brake petal.
bob4703 likes this.
1977 CJ7 - LT1/700R4 Project
2015 JKU Rubicon Hard Rock - stock
2013 JK Sahara - gone
REDnBLUES is offline
