Brake line source - JeepForum.com
 6Likes
  • 2 Post By ADDZ71
  • 1 Post By Nor Cal CJ5
  • 2 Post By CSP
  • 1 Post By John Strenk
post #1 of 11 Old 05-19-2021, 05:25 AM Thread Starter
Beninct
Beninct's Avatar
Brake line source
Can someone post a link to a decent set of flex brake lines that will work with my 85 CJ7? Stock drums in back and I need the flex lines at each rear wheel and the center hose that comes down to the diff from the frame.
I will make my own steel lines along the axles.
Please/Thanks!
Beninct is offline
post #2 of 11 Old 05-19-2021, 05:29 AM
ADDZ71
1979 CJ7
There are no flex lines at each rear wheel. There is only a flex line running from the cross member to the axle. If memory serves me correctly it is just on the right side of the differential to a junction which splits and runs to each side. Everything from the junction to wheel cylinder is a hard line.
OrangeCJ-5 and Beninct like this.
ADDZ71 is offline
post #3 of 11 Old 05-19-2021, 09:00 AM
Nor Cal CJ5
Nor Cal CJ5's Avatar
1972 CJ5
I was sent a wrong center rear flex line new and will send it to you for shipping. If you PM me the part number you are looking for, I will verify what I have with you. Pretty sure it’s a line made for your Jeep.
1972 CJ5 304 V8, 3 speed manual trans
Nor Cal CJ5 is offline
post #4 of 11 Old 05-19-2021, 10:15 AM
Nor Cal CJ5
1972 CJ5
The rear center brake line I have is a OMIX 16733.02 Part number. Part number for a 1985 CJ7 is 16733.03. The funny thing about any description about brake lines on any online site is that they never includes the important info like the connection sizes, only the years that it will work. I have found that you need to measure and verify fitting sizes and hose lengths, etc.
This hose has the same 3/8" size female connection at the 3 connection points, and the hose is 17-3/4" long. The axle attachment thru hole is 3/8" also.
Beninct likes this.
post #5 of 11 Old 05-19-2021, 01:11 PM
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
I would wager that they don’t tell you that because it is based off of what was originally in the vehicle. Who knows what has been done to a vehicle that is 36 years old? My preference is to stick with Wagner and Bendix for brake parts. I definitely wouldn’t have chosen Omix.
OrangeCJ-5 is offline
post #6 of 11 Old 05-19-2021, 02:21 PM Thread Starter
Beninct
Beninct's Avatar
Yes not sure what I was thinking (just lifted my 07 JK so prob had that on my mind!). Thx
Beninct is offline
post #7 of 11 Old 05-19-2021, 03:06 PM
Nor Cal CJ5
1972 CJ5
I wouldn't have chosen OMIX either, but try finding a water pump for a 1972 304 (the right shorter one and not OMIX either), or many, many other parts. Every sales person will tell you "oh yeah, it will fit", then won't take returns or it isn't worth sending back. The 1972 Jeep was a one and done year for lots of parts and nobody makes parts for one and done 50 years later. So sometimes it's good to find something that will work - even if it is OMIX. I really only look for stock parts.
I did find front brake hoses OMIX and they work fine - similar quality to originals. But I understand your point.
Forget about an OMIX upper steering shaft bearing, it's like buying a wedding ring out of a gumball machine.
post #8 of 11 Old 05-19-2021, 04:36 PM
CSP
Google Crown stainless brake lines. They make great lines and it is not the same Crown company that makes POS Jeep parts.
This assumes you have a lifted CJ and need a longer line. If not, get a replacement from a local parts store. This isn't a specialty part if it is still on the stock suspension.
John Strenk and OrangeCJ-5 like this.
CSP is offline
post #9 of 11 Old 05-20-2021, 03:14 PM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
search www.inlinetube.com
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is offline
post #10 of 11 Old 05-22-2021, 06:43 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I put on a set of Goodridge Braided SS brake lines and the difference between old rubber flex line and these are remarkable.
If I ever need to replace them I'll look at Crown.
Beninct likes this.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #11 of 11 Old 05-23-2021, 07:06 PM
CSP
Those Goodridge are nice lines too. I forgot about that brand.
CSP is offline
