Bmann412's AMC 304 Rebuild - Page 7 - JeepForum.com
 44Likes
post #91 of 262 Old 03-25-2020, 12:03 PM
Axhammer
Axhammer's Avatar
Use the dial indicator to find TDC. At TDC the piston is either below, even or above the deck. You can use a straight edge and a feeler gauge to measure the dimension. If you look at my picture, my piston is sticking out of the hole about .005”, which is where I want it for a tight quench. With a .040” head gasket, my piston will be about .035” from the cylinder head at TDC.
To check the balancer, install the balancer & timing chain cover. Find TDC of #1 using your dial indicator. At this point the balancer should be aligned with “0” degrees timing.
Matt1981CJ7 likes this.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is offline
post #92 of 262 Old 03-27-2020, 03:20 PM Thread Starter
Bmann412
Bmann412's Avatar
1930
Made some good progress on the motor today. First I found top dead center using a piston stop and cam degree wheel. With top dead center found I setup my dial indicator on one of the lifters and verified that the cam matches the cam card.
Results:
Intake on cam card: 109
Intake as measured: 109.5
Exhaust on cam card: 112
Exhaust as measured: 112.5
With the camshaft’s position verified I put the engine back at top dead center and loosely installed the timing cover and loosely installed the harmonic balancer. It lined up with the TDC mark on the timing cover. I also measured the distance between the deck and the piston face. The piston sits .035 from the deck so I shouldn’t have any issues with piston to valve clearance.
1998 TJ 5.9l
1978 CJ7 Renegade
2013 JK
Bmann412 is offline
post #93 of 262 Old 03-27-2020, 03:23 PM Thread Starter
Bmann412
Bmann412's Avatar
1930
Also picked up some play dough to measure the oil pickup to pan clearance. With no gasket installed It came out to be a little over 3/8” so I might back it up a bit the service manual says between 1/4” and 3/8”
1998 TJ 5.9l
1978 CJ7 Renegade
2013 JK
Bmann412 is offline
post #94 of 262 Old 03-27-2020, 05:32 PM
oldschool74cj5
Bmann
im glad that the plado trick worked for you. when i use to build engines that is one of the tricks we used to get a accurate height. used to do more with old mopars but a engine is a engine.
AxHammer
question in that pic is a build of a stroker. i saw the dished out pistons and was wondering if so what compression did you end up with? the only reason i was asking is im thinking of building a carbed stroker for my cj7. unfor i do love inline 6 tractor motors.
oldschool
oldschool74cj5 is offline
post #95 of 262 Old 03-27-2020, 06:03 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
Are you considering purchasing a new harmonic balancer? I've seen worse.
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is online now
post #96 of 262 Old 03-27-2020, 06:08 PM
Shawn Watson
Shawn Watson's Avatar
1983 CJ7
Nice job, Bmann
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
Shawn Watson is online now
post #97 of 262 Old 03-27-2020, 06:12 PM Thread Starter
Bmann412
Bmann412's Avatar
1930
Wasn’t sure was hoping to get some opinions. I am not seeing a lot of options for the 304. So far the damper doctor seems to be the most cost effective option.
Originally Posted by oldschool74cj5 View Post
Bmann
oldschool
Thanks again, I wouldn’t have known how about to check the clearance other wise. Would you leave the pick up where it is or move it up a little bit?
1998 TJ 5.9l
1978 CJ7 Renegade
2013 JK
Bmann412 is offline
post #98 of 262 Old 03-27-2020, 07:19 PM
oldschool74cj5
Bmann
unfortunately i am a perfectionist when it comes to mechanical things. i would really have to look at it all. depending how large the pan bottom is it would leave about a 1/2-3/4 quart of oil that would be below the pickup. i think it hold about 6qts when full. that is a good amount of oil to displace to uncover the pickup. if i remember the oil pick up is threaded into the block? so to me that means there really only two ways to close the gap between the pan and pickup. one way that isnt a good thing is have it not threaded into the block as far. a possible problem there would be sucking air into the oil system. speak of threaded fitting hopefully you put something on the i the only other way i can think about is tweeking the tube some to get it to sit closer to the pan. depending on how thick the tube is i would look at that option if i would try to get tighter clearance.
as for a harmonic balancer i would get a new one just because you have that much work into a new motor. you wouldnt want a problem with a new motor because of a old so so part. rock auto has some for the 304 engine if you look at 79 and older cj's
oldchool
post #99 of 262 Old 03-27-2020, 08:16 PM Thread Starter
Bmann412
Bmann412's Avatar
1930
Bmann
oldchool
Nothing wrong with being a perfectionist. So if I am understanding this correctly there is really only one way the pickup tube can be installed since it is threaded on. Comparing the new pick up to the original and the bends appear to be in same spots so I wouldn’t like to try and bend it unless it’s necessary. I agree that it would take a lot to displace the that much oil to starve the pickup. The way I see it there is no real need to change the distance between the pan and pickup unless someone else see’s something wrong with the current location.
As for the harmonic balancer I agree it wouldn’t be wise to use old parts when I have put this much time and money into a fresh motor.
1998 TJ 5.9l
1978 CJ7 Renegade
2013 JK
Bmann412 is offline
post #100 of 262 Old 03-28-2020, 08:35 AM
Axhammer
Axhammer's Avatar
Looks good Bmann. 9 out of 10 cams will be dead on or very close when installed dot to dot, but eventually you will get one that is off when installed dot to dot. That’s when degreeing the cam pays off, because you make adjustments to get it right one way or the other. My current race engine has a 2 degree offset key from Mopar. That Mopar offset keyway set was hanging on my wall for over ten years, and then one day I used one of the keys to get my cam timed correctly. That day convinced me to always put the degree wheel on and verify it.
I forget what the target CR is on my 4.7 build. I called Russ Pottenger, and bought the parts from him to run 87 octane gasoline. It’s a little higher than you would guess, but the .035” quench makes it possible. I’ll call Russ and find out, and post it. I’d like to get it in a thread that might help someone else putting the parts together for the stroked I-6 engine.
Axhammer is offline
post #101 of 262 Old 03-28-2020, 09:03 AM Thread Starter
Bmann412
Bmann412's Avatar
1930
Thanks! I would rather take the time to check as much as possible so there is less to worry about when starting it up.
Maybe I missed something but what does CR stand for? So the reason you are running the higher octane gas is due to your engine being a stroker. Should I be running a higher octane fuel in my Jeep?
1998 TJ 5.9l
1978 CJ7 Renegade
2013 JK
Bmann412 is offline
post #102 of 262 Old 03-28-2020, 10:47 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
CR is compression ratio. Higher compression ratio needs higher octane fuel.
Matt
Matt1981CJ7 is offline
post #103 of 262 Old 03-28-2020, 10:57 AM Thread Starter
Bmann412
Bmann412's Avatar
1930
Matt
That makes more sense Thanks Matt
1998 TJ 5.9l
1978 CJ7 Renegade
2013 JK
Bmann412 is offline
post #104 of 262 Old 03-28-2020, 12:22 PM
Axhammer
Axhammer's Avatar
My 1995 (4.0 based) inline six 4.7 is designed to run around 9/1 CR on regular unleaded gasoline 87 octane. For comparison the 468 in my race car has 12.8/1 CR, I run E-85 (ethanol based fuel), which will support up to 14/1 CR. You can go to the website below for a CR calculator, and see what your 304 engine CR will be. FYI most OEM style or replacement head gaskets are around .040” thick and the head gasket opening is larger to account for overbore situations. If you don’t have a gasket to measure input an extra .2” into the calculator to get is close.
http://www.wallaceracing.com/Calculators.htm
Axhammer is offline
post #105 of 262 Old 03-28-2020, 05:02 PM
Nor Cal CJ5
Nor Cal CJ5's Avatar
Originally, there is a plastic button on the bottom of the oil pump pick up to provide clearance to the pan. Lots of times you will find this missing. To correct this, people install a bolt and nut through this hole (with Loctite) or weld on a spacer to provide the proper clearance. A worse thing could be the pick up sucking to the bottom of the pan and starving the motor of oil.
Sorry not to be able to attach pictures yet... If you would like to see a picture of what I'm describing, PM me and I will send by e-mail.
Thanks,
Greg
Nor Cal CJ5 is offline
