Blinker dash indicator stays illuminated - JeepForum.com
 1Likes
  • 1 Post By adman02
post #1 of 6 Old 10-13-2019, 02:24 PM Thread Starter
cpadget
cpadget's Avatar
1983 CJ7
Swapped out my steering gear, shaft, and bearing; now my left blinker indicator light stays illuminated full time when headlights are on. It flashes when I activate the blinker, then stays lit solid once the steering wheel clicks it off on the return to straight. ANY IDEAS????
cpadget is offline
post #2 of 6 Old 10-13-2019, 03:23 PM
agear
Which parts did you take apart ? Reason I ask is those areas are prime candidates. My blinker light comes on the speedometer when I have a turn signal or marker light out
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is online now
post #3 of 6 Old 10-13-2019, 05:43 PM
rfine
check your exterior bulbs, that is a safety to let you know that one is burned out
rfine is offline
post #4 of 6 Old 10-13-2019, 07:20 PM
adman02
1979 CJ7
Check your grounds.
John Strenk likes this.
adman02 is offline
post #5 of 6 Old 10-13-2019, 07:38 PM Thread Starter
cpadget
cpadget's Avatar
1983 CJ7
Thanks guys...I was quick to assume that type of indicator was reserved for our newer cars. Just checked and the yellow running light
below the headlight is OUT!!!
Thanks again
cpadget is offline
post #6 of 6 Old 10-14-2019, 05:39 AM
John Strenk
John Strenk's Avatar
1976 CJ5
This is interesting and kind of cool even if the math doesn't work out.
It might not work if you use the wrong size turn signal indicator bulb or LEDs
I never noticed this on mine because the fender marker lights always corrode away before one of my lights burned out.
Sadly,it wont indicate if one of the rear light goes out.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
