Before I buy this T-18a - JeepForum.com
 1Likes
  • 1 Post By CSP
post #1 of 11 Old 02-20-2020, 01:04 PM Thread Starter
weider1717
Guys,
Found a T-18a as I'm told it has the 6.32 1st gear and rebuilt. What will be required exactly? I am trying to read without making a new post but it depends on which t18 etc and it gets confusing.
This one its a T-18A which I read only came in 78-79 CJ's I asked him the casting on it which he said is 87-14? Surely there is more casting than that so not sure.
I read some require cutting the floor pan and more drilling etc not sure if that is the case in a cj7 or a cj5 or all?
Mine is a 78 cj7 with the 304, t-150 and dana 20
thanks for any helps with this
weider1717 is offline
post #2 of 11 Old 02-20-2020, 01:17 PM
caseypotts
caseypotts's Avatar
1980 CJ7
I didn't need to cut the floor but I did need a new tunnel cover.
caseypotts is offline
post #3 of 11 Old 02-20-2020, 01:27 PM
caseypotts
caseypotts's Avatar
1980 CJ7
post #4 of 11 Old 02-20-2020, 01:51 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
If it has the the short Ford 6-1/2" input shaft stick-out, you will need a custom pilot bushing. Novak sells them.
Your T-150 bell-housing will work fine.
Your T-150 clutch kit should work fine, as well, but it may be a good time to install a new kit.
Assuming it's a Ford T-18, you will need an adapter to mate your D-20 t-case to it.
The overall length of the T-18, with t-case adapter, will be longer than your T-150, so you will need different driveshafts.
You will need a different transmission tunnel cover, or modify the one you have.
You will probably need a different reverse light electrical connector for the T-18
Other than that, it should be a fairly straight forward swap.
Good luck,
Matt
Matt1981CJ7 is offline
post #5 of 11 Old 02-20-2020, 02:10 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
So, this is important: Is it the Jeep version of the T18 or a Ford T18? There are a few differences.
If it's the Jeep version, and it came out of a CJ, you're not going to need to gut the transmission and put in a new mainshaft. If it came out of a FSJ, you'll need a new input shaft, as it will be too long. If it's the Ford version, you will need to put in a new main shaft.
"In the end...It's all Hack."
HackFabrication is offline
post #6 of 11 Old 02-20-2020, 02:11 PM Thread Starter
weider1717
Seller says this is a “Jeep” t-18
assuming that means this came in a CJ when new
post #7 of 11 Old 02-20-2020, 08:49 PM
CSP
Don't assume anything when it comes to T18s, there are way too many possible variations to assume safely. Do not rely on casting numbers either. I could write a small book on this subject.
Some solid links with T18 information: http://www.jeeptech.com/convtrans/convt18.html (thanks Terry Howe, I'm still using this website!)
http://www.novak-adapt.com/knowledge...anual/t18-t19/
If it doesn't have an input shaft that has about 6.75" of stick out length from the front face of the case it is not a CJ version with the 6.32:1 first gear.
CSP is offline
post #8 of 11 Old 02-22-2020, 12:40 AM
RedNeckCorvette
1979 CJ7
Rotate the input shaft in 1st gear and count six at the output shaft. That, or slightly over and that problem is solved. They made a 4.02:1 ratio also.
If the input shaft is not 1-1/8'' but is smaller in diameter ''I have to think'' maybe 1-1/16'' there is a good chance it came from a CJ7 and was a factory T-18 transmission that will bolt right up to your T150. Be careful the T-18s for AMC pickups have a very long input shaft about 12 '' long x 1-1/8''
Not out of the woods yet! You will need to modify your drive lines front and rear and I would advise looking into a CV joint in the rear with a larger pipe in the front for strength, if it will fit.
Good luck get it cheep after they sit long enough people forget what they are worth.
I have a few sitting around here and there if you have further questions maybe I can answer.
Not always on line just lurking.
RedNeckCorvette is offline
post #9 of 11 Old 02-26-2020, 08:54 AM
exheep
1976 CJ5
I needed to move my skid plate back on my 76 CJ5 to accommodate the T18 . Fortunately the frame was pre-drilled with captive nuts.
exheep is offline
post #10 of 11 Old 02-27-2020, 07:53 PM
mikeyboat
1979 CJ7
I learned the hard way that not all Dana 20s are equal.
https://www.jeepforum.com/forum/f8/s...l#post40886821
I was told my T18 came out of a Wagoneer. I bought the whole drivetrain; engine, transmission, and transfercase, all bolted together with a buggy being built around it.
I knew my original transfercase from my T150 was good, so I decided to run that. Everything seemed to go together fine, could shift through all positions in the case, but I had this whine when the gears were floating - or not under load.
Pretty sure someone mentioned this possibility when I was trying to diagnose the whine, but this page right here: https://www.novak-adapt.com/knowledge/gear-table/ will let you know what works together.
mikeyboat is offline
post #11 of 11 Old 03-03-2020, 09:58 PM
CSP
You want to count how many revolutions of the input turn the output one revolution.
Yep, 1-1/16" and any 76-79 CJ could have had this transmission.
RedNeckCorvette likes this.
CSP is offline
