Bedliner Removal - JeepForum.com
 3Likes
post #1 of 21 Old 06-18-2021, 06:13 PM Thread Starter
jchal3
1934 CJ7
Bedliner Removal
Hey guys I'm trying to get all the paint and coatings off of my cj tub to see what metal needs to be replaced. Ive attacked it with sanders and beer...the paint comes off easy enough, but bodyliner was used on the inside of the tub, and that stuff just won't come out...today, I went after it with a sand blaster, and got basically nowhere in 4 hours.
What is the best way to get the bedliner off of my tub??
Sent from my SM-N960U using Tapatalk
jchal3 is offline
post #2 of 21 Old 06-18-2021, 06:16 PM
weapon
1983 CJ7
fire and scraping.
weapon is offline
post #3 of 21 Old 06-18-2021, 07:57 PM
cjoffroad
cjoffroad's Avatar
1980 CJ7
I used a needle scaler for the most part and a wire cup. Worked pretty good, but be careful the needle scaler will also show you where the metal needs replaced.
cjoffroad is online now
post #4 of 21 Old 06-18-2021, 09:05 PM Thread Starter
jchal3
1934 CJ7
Thanks guys...have you heard of any chemicals to try?
jchal3 is offline
post #5 of 21 Old 06-18-2021, 09:54 PM
jeep_boy02
1934 CJ7
Fourwheeler did a "what works best" write up about 6 months or so ago and I believe aircraft stripper worked the best. Lay it on thick and let it sit.
Heres a link to some of the info
https://www.fourwheeler.com/how-to/b...liner-removal/
Sent from my SM-A015A using Tapatalk
80 CJ7-304/T176/D300 HEI hdrs-WT D30/D44 4.56s, lockright/spool-SOA YJs W/RE AAL-35 MTRs beadlocks
jeep_boy02 is offline
post #6 of 21 Old 06-19-2021, 12:57 PM
torkman1983
Retired Air Force
1983 CJ7
Using chemicals will be very messy. I had it on the underside of my tub. Found that using an air chisel with a flat end worked really well. Just have to be careful to keep chisel flat enough so it does not ding the metal, just removed the liner.
torkman1983 is offline
post #7 of 21 Old 06-19-2021, 01:07 PM
Ollie09
1977 CJ5
I used one of these. Worked great on the under coating.
https://www.harborfreight.com/6-piec...kit-95826.html
Ollie09 is offline
post #8 of 21 Old 06-20-2021, 06:05 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Bedliner is a 100% polyurethane, 100% polyurea, or a hybrid of both. Particles are sometimes included, some are rubber.
This stuff is tough with excellent adhesion, so you will need to get rough to remove it mechanically.
Polyurethane dos not soften when heated, but it can burn which produces carbon monoxide and hydrogen cyanide, in addition to nitrogen oxides, isocyanates, and other toxic products. So trying to burn it off could go badly wrong.
If you want to use chemicals little touches it as it is inert but methylene chloride is good at removal. Also known as Dichloromethane (DCM), Methylene Dichloride and Methane Dichloride. it is bad stuff!!!
Best way is to mechanically take it off and use a face mask (easy to find now) and goggles. Then have a paint system ready to kill residual rust and prime.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #9 of 21 Old 06-20-2021, 08:43 AM
mudbfun
1973 CJ5
I have the same job ahead of me, not looking forward to it. I plan on trying a coarse wire wheel like CJoffroad used. Apparently the PO thought bedliner is a cure for rust.
mudbfun is offline
post #10 of 21 Old 06-20-2021, 07:14 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Rust is one of the few things that will lift bedliner!!!!
mudbfun likes this.
post #11 of 21 Old 06-20-2021, 07:15 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
I can see the attraction of bedliner in a cargo bed which sees a lot of action and no rubber mat but in a small utility Jeep it is harder to justify. I put rubber floor mats.
post #12 of 21 Old 06-20-2021, 09:50 PM
ravenworks
ravenworks's Avatar
I am so glad that I never put bedliner down.
Someone beat me to that article,it is helpful
JoonHoss likes this.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #13 of 21 Old 06-20-2021, 10:02 PM
mudbfun
1973 CJ5
I think it would be great for an undercoating if used right, otherwise I agree. Save it for the truck beds.
After reading this thread I saw a couple of videos of people using citrus strip and covering it with plastic for about a day. Looks like that might work pretty good.
mudbfun is offline
post #14 of 21 Old 06-23-2021, 01:30 PM
magnetman
Caveman Chemist
magnetman's Avatar
2010 JK Wrangler
Good old fashioned methylene chloride paint remover with good ventilation is the only thing that will work or the needle scaler someone else mentioned.
Depending on what type of liner was used, DIY vs sprayed in polyurea Line-x/Rhino type, sanding or sand blasting will have varied results. The fact that you tried blasting with little results shows that it's probably not a DIY product in there or your blaster didn't have enough muscle behind it
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #15 of 21 Old 06-25-2021, 05:04 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
This one is still in step one
Then step two
Let the scraping begin after it cools some.
It may come off EZer if some of the heat is retained.
----JEEPFELLER
mudbfun likes this.
JEEPFELLER is offline
