Axles on my 81 cj5 - JeepForum.com
 4Likes
  • 1 Post By Hurricane4
  • 2 Post By BagusJeep
post #1 of 8 Old 09-07-2019, 11:13 PM Thread Starter
Eberle
Axles on my 81 cj5
Anyone know the difference between the Dana axles, I have know idea which one I have
Eberle is offline
post #2 of 8 Old 09-08-2019, 12:04 AM
Hurricane4
1979 CJ5
Your '81 CJ5 came stock with a Dana 30 front axle (1972-1983) and an AMC model 20 rear axle ('76 and up) with 2 piece axles - axle & hub.
Good sources of info on the sites below:
http://www.jeeptech.com/models/cj-5.htm
https://www.jeeptech.com/axle/amc20.html
ddawg16 likes this.
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is offline
post #3 of 8 Old 09-08-2019, 12:08 AM
Hurricane4
1979 CJ5
Also - Please fill out as much information about your Jeep in your profile.
Forum members can quickly view this data and provide an accurate response to your question.
trailhead2004 likes this.
Winston Churchill
post #4 of 8 Old 09-09-2019, 08:54 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Accurately wrong usually!!!
A first guess from the shape of the diff cover. A Dana 44 is very different to an AMc20!!
trailhead2004 and ddawg16 like this.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 8 Old 09-09-2019, 09:11 AM
hp_lovecraft
1981 CJ5
Yes, probably a Dana30 and AMC20. Swaps and upgrades are so common in the Jeep world, nothing is safe to assume.
Dana44 are common swaps. Also, in 1980, the CJ7/8 got a wider axle, while the CJ5/6 kept the narrow style. I've seen a few CJ5 with the wider axles swapped in. The AMC20 had a 1pc axle, but 2pc axle swaps are super common.
Gear ratios are all over the place. 2.73, 3.31, 3.54, 3.73, 4.10, etc. The "standard" ratio depended on your engine size. They was also had a limited-slip option, track-loc. There will be a letter code on the axle that will tell you what it came from the factory with.
People often got Jeeps with lower ratios because of "fuel efficiency", but it becomes a dog once you put bigger tires in. SO... gear ratios are also swapped around. Its also common to see welded spiders and lunchbox lockers.
So.... maybe a stock AMC20 and Dana30. Maybe not. lol
hp_lovecraft is offline
post #6 of 8 Old 09-09-2019, 05:23 PM
Hurricane4
1979 CJ5
I do realize the OP's Jeep could have had an axle swap.
All I was trying to do was post the factory OEM axles the Jeep was equipped with when new.
Winston Churchill
post #7 of 8 Old 09-09-2019, 09:39 PM
CSP
The wide track axle use started in 1982. The last year of the CJ6 for US domestic markets was 1975, exports stopped after 1980.
CSP is offline
post #8 of 8 Old 09-09-2019, 10:02 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
if you can identify them as Dana axles, they all have a build code stamped into the axle tube. There were tags on the diff covers when new, find very few have survived.
