Axle help - JeepForum.com
 1Likes
post #1 of 19 Old 11-08-2019, 10:52 AM Thread Starter
jcoutu
Axle help
Hello, I removed a D20 from a CJ frame. Measuring center to center for spring perches, it is about 36". I bought a D44 that I was told came off a CJ, however the spring perches are about 4" closer to each other. In researching CJ frame dimensions, I cannot see how this axle came off a CJ. The guy I purchased it from insists it is off a CJ, and AMC vs Jeep ownership made changes all the time including frame width in the rear which I assume is directly related to spring perches location. He refuses refund and also said just grind off the existing and weld in replacements, however that narrowness may be a problem? It seems the backing plates for the wheels may cause rubbing issues in the rear. I'm pretty ignorant on this issue and pretty much know I'll get a proper answer here. Thanks in a advance. James
jcoutu is offline
post #2 of 19 Old 11-08-2019, 11:23 AM
RiverandSand
1980 CJ5
The Dana 44 came in jeeps CJs, FSJs also other makes as well. The Narrow track 76-81 cj will measure 50.5" backing plate to backing plate, purch to purch is 36". Widetrack 82-86, 54.5" b to b and purch measure is the same a narrow track. The Dana was dropped in 76 by AMC, but was used again in 86 as AMC 20s supplies dwindled.
What are your measurements?
keith460 likes this.
RiverandSand is offline
post #3 of 19 Old 11-08-2019, 11:35 AM Thread Starter
jcoutu
The D44 backing plate to backing plate is 45". Didn't measure spring perch center to center, but guessing about 32" center to center. I have a pic but can't seem to figure out how to add.....
jcoutu is offline
post #4 of 19 Old 11-08-2019, 11:50 AM Thread Starter
jcoutu
Pic comparing the original D20 to the D44 showing spring perch locations, it really narrow.
jcoutu is offline
post #5 of 19 Old 11-08-2019, 12:42 PM
letitloose06
letitloose06's Avatar
That looks like a centered D44 from a 72-75 CJ5. The 72-75 CJ5 had a much narrower frame in the rear.
1992 YJ 4.0L, AX-15, 4" RE Standard Lift, 35x12.5R15 Maxxis Bighorn MT's, Grizzly Locked 8.8 Rear, HP44 with Spartan, 4.10's, Smittybilt Armor, JCR Off road Stage 2 Front Bumper, Custom Rear Bumper
1966 M416 1/4 Ton Cargo Trailer --
1951 CJ3A Restomod Project
letitloose06 is offline
post #6 of 19 Old 11-08-2019, 02:29 PM
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
The Dana 20 is a transfer case. What axle was in the Jeep: AMC 20?
OrangeCJ-5 is offline
post #7 of 19 Old 11-08-2019, 03:03 PM Thread Starter
jcoutu
Oh? OK I didn't know the CJ5 came with a narrower frame. That makes sense now. All the frame specs I was able to research (seems I did not do enough) show the CJ5 and CJ7 widths at the rear, the same. With b plate to b plate at 45" I'm not going to use this axle, getting another wide D44 from a friend.
jcoutu is offline
post #8 of 19 Old 11-08-2019, 03:08 PM Thread Starter
jcoutu
Ah, makes sense. All the specs I've seen for CJ5 and CJ7 frame width at rear were the same... Guess I didn't find the right info. Thanks I'm still concerned about the 45" back plate to back plate spacing. Probably will not use this axle.
jcoutu is offline
post #9 of 19 Old 11-08-2019, 03:09 PM Thread Starter
jcoutu
Ops yes the xfer case is D20 and the axle is AMC20
jcoutu is offline
post #10 of 19 Old 11-08-2019, 03:13 PM
Fourtrail
1974 CJ6
55-75 CJ-5 and CJ-6's had a straight frame, they did not flare out wider under the pass compartment.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #11 of 19 Old 11-08-2019, 04:01 PM
only in a jeep cj
In regards to matching the stock width of what you have, a 72 to 75 CJ 5 /6 rear Dana 44 will need to have its spring perched cut and moved to match the wider rear frame spacing used on the 76 on frames. This will work up to 83 CJ5 or 81 CJ 7 as these used the narrow track axles.
For it to be a direct bolt in on the 82 to 86 CJ7/8 for both the width and perches, a Dana 44 from a late 86 CJ7 will need to be used.
If a wider 44 is desired, a Scout II rear axle will still need the perches moved, but the bolt pattern is still 5 on 5.5
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 2003 Inca Gold TJ Rubicon
2012 JKUR RHD
only in a jeep cj is offline
post #12 of 19 Old 11-08-2019, 09:07 PM
CSP
The 72-73 Commando D44 is a bolt in for any '76-86 CJ and is narrow track width.
The Commando had the springs outboard of the frame rail and the perch to perch width matches '76 and up CJs.
It has nothing to do with what model CJ it is, it's the year.
CSP is offline
post #13 of 19 Old 11-08-2019, 11:25 PM Thread Starter
jcoutu
I do not understand something. The narrow track axles seem to be 50.5" and the wide 54.5. This axle is 45" plate to plate and this is very confusing. Even though I can relocate the spring perches, why is the width so short? And, if an imbalance with the width of the front, what should I expect?
jcoutu is offline
post #14 of 19 Old 11-09-2019, 12:18 AM
skizriz
skizriz's Avatar
1978 CJ7
Arent those old 44s two piece, 19 spline axles?
What are you trying to accomplish by swapping the axle?
skizriz is offline
post #15 of 19 Old 11-09-2019, 10:07 AM
Axhammer
Axhammer's Avatar
The narrow and wide track measurements are measured “Wheel mount surface” (WMS) to WMS. Your backing plate measurement is what is throwing you off. That is not a commonly used place to measure a rear end assembly.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is online now
