Anyone have a Flex-a-lite 575 fan on their CJ7? - JeepForum.com
post #1 of 25 Old 12-07-2008, 09:46 PM Thread Starter
OSUAV8R
I was wondering what you guys think of it, I am finishing up a rebuild and was wondering if it was worth the $330 for the fan or just stick with the stock fan.
I have an 85 CJ7 with a 258
Thanks
Nathan
OSUAV8R is offline
post #2 of 25 Old 12-07-2008, 09:51 PM
hlosada
Guest
I have it on my 92 YJ with a 4 cylinder
Installed to give more HP to the wheels and have power to turn off and on when I want to, off while crossing deep water
hope this helps
Henry
hlosada is offline
post #3 of 25 Old 12-07-2008, 09:52 PM Thread Starter
OSUAV8R
Henry, did you see a real improvement?
OSUAV8R is offline
post #4 of 25 Old 12-07-2008, 11:22 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Go with the Contour/Mystique dual fan:
Available in your friendly P&P for under $50, they pull 3200 cfm, and draw under 20amps when running on high.
"In the end...It's all Hack."
HackFabrication is offline
post #5 of 25 Old 12-07-2008, 11:47 PM
VACJ7
VACJ7's Avatar
I am finishing up my Contour fan now and Hack has some great info on this setup! Fan ran me $30, plus a FAL controller for ~ $100.00.
VACJ7 is offline
post #6 of 25 Old 12-08-2008, 06:19 PM Thread Starter
OSUAV8R
what is a FAL controller, how hard is it to set up?
OSUAV8R is offline
post #7 of 25 Old 12-08-2008, 06:21 PM
mike4089
I had the flex a lite 575 fans, and they were awesome...I just got rid of them because my new aluminum radiator that i am using for the 5.3 swap wasnt wide enough...so i bought the 160s blade fan from them with thermostat control...very happy so far
mike4089 is offline
post #8 of 25 Old 12-08-2008, 06:28 PM Thread Starter
OSUAV8R
want to sell the 575?
OSUAV8R is offline
post #9 of 25 Old 12-08-2008, 06:41 PM
Fjguercio
1978 CJ7
hope this helps
Henry
Does it help with your HP to the Wheels???? I am thinking the same thing. Does this add a little pep to a 4 or 6 banger. The I6 is a 100-120 HP engine would this yield 5-10 HP??? What do you think?? Could also yield a little mpg also.
X2 on the Countour Electric FAN.... I printed all that info... good stuff. Nice job Hack and the others that posted about a month ago. Someone should post the link to that write up here, it was about the controlers if I remember right.
I went and looked. Here is the link. EXCELLENT!!!!https://www.jeepforum.com/forum/showthread.php?p=6024819
Thanks,
Fred
Fjguercio is offline
post #10 of 25 Old 12-08-2008, 06:57 PM
mike4089
already sold...sorry!
mike4089 is offline
post #11 of 25 Old 12-08-2008, 07:04 PM
1980tallcj7
1980tallcj7's Avatar
1980 CJ7
Thanks
Nathan
I have a flexilite twin electric fan on my rig ....it cools very good, was easy to install, and haven't had a lick of trouble with it in 2 years.. [knock wood]
Steve
1980 CJ7,
1980tallcj7 is offline
post #12 of 25 Old 12-08-2008, 08:32 PM
Mike78cj7
1978 CJ7
Contour fans are the way to go. Cheap and easy to install. Plus I think they look better then an aftermarket fan.
Mike78cj7 is offline
post #13 of 25 Old 12-08-2008, 08:45 PM
VACJ7
VACJ7's Avatar
FAL is just short for Flex-A-Lite. There are few ways to go. Hack is using the 31163 controller (variable speed and temp probe directly into coolant). I went with the 31165 controller (60/100% speed and temp probe poked through radiator fins). Both have connections for AC and a way to wire up a kill switch to turn them off for deep water crossings. I have not finished my install yet but think it will work fine for my use. JeepHammer posted up a diagram on how to do it without a FAL controller using relays, etc.
This is the thread that sparked my interest in the Contour fan.
https://www.jeepforum.com/forum/showt...ht=contour+fan
VACJ7 is offline
post #14 of 25 Old 12-08-2008, 10:52 PM Thread Starter
OSUAV8R
For those of you with the fans, do you really notice any improvement in power and MPG. What other benefits have you noticed?
OSUAV8R is offline
post #15 of 25 Old 12-09-2008, 12:40 AM
HackFabrication
1976 CJ5
One benefit of the FAL 31163 is that it will soft start the fans at 60% by 'hitting' the motors with spikes of voltage/current to get them turning, eliminating the need for relays. Electric fan motors draw large amounts of current to start, then 'settle down' to a lower current draw as they reach designed rpms. As an example (numbers not accurate) a Taurus 3.8L fan may draw up to 80 amps when starting on high, but will only draw 30-35 amps when running on high. Which is why you either have to use really heavy gauge wire and switches, or use relays to handle the initial current draw.
I can't speak for performance or mileage increases: I've got a Ford Racing 5.0L engine rated at 345hp on premium pump gas, with 4.56 gears. I'll be estatic if I get 12mpg....
Anyone used a Flex-a-lite Mojave heater? LivesIn10sly Jeep CJ Forum 14 01-20-2019 06:45 PM
78 cj-5 brake lite, blinker woes jimdubose Jeep CJ Forum 2 01-02-2009 10:30 PM
Flex-A-Lite fan wiring question danheit Jeep CJ Forum 1 11-26-2008 09:41 PM
Did a little lite wheeling yesterday. wvabreeze Jeep CJ Forum 5 03-23-2008 09:57 PM
will it flex enough? jeepnut00 Jeep CJ Forum 2 04-18-2005 10:50 PM
