Anybody running a dana 44 from an 86 cj - Page 2 - JeepForum.com
post #16 of 30 Old 06-27-2021, 01:16 PM
80cj
80cj's Avatar
1980 CJ5
All the rearends, frontends I've regeared I did on a couple wooden saw horses. Lay the pinion yoke holding fixture across a saw horse and 210 ft. lbs on a 44 pinion not a problem. Crushing a AMC 20 and Ford 8.8 crush sleeves a little more difficult but I managed using the same method.
80cj is online now
post #17 of 30 Old 06-27-2021, 02:19 PM Thread Starter
agear
Cool..well its bolted in the jeep now . So now im gonna break out the torque wrench and start adjusting outer pinion shims
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #18 of 30 Old 06-27-2021, 03:08 PM
davcono
davcono's Avatar
Bought my D44 from East Coast Gear Supply. Dont know if they sell parts, but they could probably give you some info.
davcono is offline
post #19 of 30 Old 06-27-2021, 03:26 PM Thread Starter
agear
Damn ! Nice !
agear is offline
post #20 of 30 Old 06-28-2021, 12:07 PM Thread Starter
agear
Backlash is only 3 or 4 after I pressed on carrier bearings so I messed up my shim count when preloading I guess. Have to wait till tomorrow to correct
agear is offline
post #21 of 30 Old 06-28-2021, 03:29 PM Thread Starter
agear
Well I went ahead and experimented with my set uo bearings (preloaded) . Backlash .006-.008
http://www.youtube.com/watch?v=kJCLCverZok
Still favors heel a little.. Can't decrease backlash. So maybe I could subtract. 002 inner pinion shims
agear is offline
post #22 of 30 Old 06-29-2021, 06:28 AM Thread Starter
agear
Bump
agear is offline
post #23 of 30 Old 06-29-2021, 01:18 PM Thread Starter
agear
I ended up putting on new carrier shims . These patterns are with set uo bearings ( preloaded
http://www.youtube.com/watch?v=glSo4He1pX8
Backlash .008- .009
agear is offline
post #24 of 30 Old 06-30-2021, 02:45 PM Thread Starter
agear
We should be good. I'm gonna roll with what I got. Got the axles and wheel cylindees and brake lines in (brake lines are a pita by the way). I checked backlash in 3 spots got .007 to .008 in those 3 spots. I did have 1 or 2 tight spots iwhere I got .005 but I don't know what's up with that. Spec is . 006 to -.010. . I)l post a video of my final patterns atleasr the ones I didn't wipe ti check backlash .
agear is offline
post #25 of 30 Old 06-30-2021, 05:28 PM Thread Starter
agear
https://youtu.be/pJrI1PqnjgY
agear is offline
post #26 of 30 Old 07-01-2021, 07:13 AM Thread Starter
agear
Maiden voyage went well. Now I just have to break them in
agear is offline
post #27 of 30 Old 07-01-2021, 08:42 AM
BrutusBlue
1982 CJ7
If it seems quite then run it.
BrutusBlue is offline
post #28 of 30 Old 07-01-2021, 08:45 AM Thread Starter
agear
Yep yep thanks !
agear is offline
post #29 of 30 Old 07-05-2021, 10:07 AM Thread Starter
agear
Originally Posted by Copper_LS_CJ7 View Post
I have a list of parts for the 86 rear dana 44 on my website, lsxjeep.com. shows the seals, retainers, bearings, and other parts if you want to put a disc brake kit on it.
ignore the amazon affiliate, i'm not anymore. just helpful information.
Do you happen to know the part number for the original drum brake shoes and drum. According to an online parts site ,I was looking at , the drums that were on there and the replacement drums I got are fir an amc 12 bolt. Obviously we have a 10 bolt dana
Update now the drivers side is quiet but the passenger side is still scraping. Now again leaning toward bent out backing plate from shipping and handling. It looks to be only rubbing on the bottom of the backing plate
agear is offline
post #30 of 30 Old 07-10-2021, 02:20 AM Thread Starter
agear
If ut turns out not to be a bent backing plate ; i have a question.
Could it be that I used permatex on both sides of the bearing retainer . Just a smeared layer on both sides of the retainer ?
Nm it would be just a few hundredths of an inch
agear is offline
