Anybody running a dana 44 from an 86 cj - JeepForum.com
post #1 of 30 Old 06-21-2021, 02:00 AM Thread Starter
agear
I got a dana 44 . And I need to order some seals and verify something. For the axle tubes out of an 86 there's one shorter side and one longer right ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 30 Old 06-21-2021, 08:16 AM
scooby533
I’ve got one torn apart in the garage. Give me a hot minute and I’ll circle back.
Edit; Driver side tube from cast to outboard part of flange = 20 1/4”
Passenger 16 1/2”
scooby533 is offline
post #3 of 30 Old 06-21-2021, 09:54 AM
orange150
1982 CJ8
I'm running one as well if you need anything else
'82 CJ-8
258/AX15/D300
OME YJ 2.5"/31s
D30/D44/3.73s/Truetracs
orange150 is offline
post #4 of 30 Old 06-21-2021, 01:11 PM Thread Starter
agear
Good good ty. My dumb arse tossed the seal retainers now im trying to find some. I had inner seal like things in there. They look like all rubber to me. Don't know if its age or not
Edit.
And also the outer seal retainers
Edit i found an outer seal kit
16243025542967281248719157125074_1624302596367.jpg   1624302623254229041940397705145_1624302634304.jpg
agear is offline
post #5 of 30 Old 06-22-2021, 03:26 AM Thread Starter
agear
Edit.
Edit i ordered 2 inner seals for an early 70s 44. Thing is why is the one all rubber i don't even see a spring on what was in there
agear is offline
post #6 of 30 Old 06-22-2021, 05:37 PM
Copper_LS_CJ7
Copper_LS_CJ7's Avatar
I have a list of parts for the 86 rear dana 44 on my website, lsxjeep.com. shows the seals, retainers, bearings, and other parts if you want to put a disc brake kit on it.
ignore the amazon affiliate, i'm not anymore. just helpful information.
Check my build out at
Copper_LS_CJ7 is offline
post #7 of 30 Old 06-23-2021, 03:33 AM Thread Starter
agear
Cool , ty !
agear is offline
post #8 of 30 Old 06-25-2021, 01:36 AM Thread Starter
agear
So you are not running an inner seal on the 44 ?
agear is offline
post #9 of 30 Old 06-25-2021, 11:23 AM
Copper_LS_CJ7
Nope, never was one in my rear axle housing, the seals on the end of the tubes keep the oil in, there aren't even any bosses in the pumpkin housing for an inner seal. Also, the rear axle is vented on the passenger side tube instead of the pumpkin because there is no inner seal in it. The reason for this is so the oil lubricates the bearings at the end of the rear tubes. No grease packing on this setup from the factory.
post #10 of 30 Old 06-25-2021, 02:19 PM Thread Starter
agear
Ty very much . Waiting on shims so I can get this thing preloaded.
agear is offline
post #11 of 30 Old 06-26-2021, 11:34 AM Thread Starter
agear
I guess I'm out of luck trying to preload this by torqueing ut to 200 lb ft resting on Jack stands
agear is offline
post #12 of 30 Old 06-26-2021, 11:43 AM
80cj
80cj's Avatar
1980 CJ5
Even with no shims in place? What brand ring and pinion ?
80cj is offline
post #13 of 30 Old 06-26-2021, 12:28 PM Thread Starter
agear
Yukon gears. What i meant was when I put a torque wrench on the yoke nut i just lift the axle housing off the jack stands when trying to torque it to 200. I cant really began to torque it down . Don't get me wrong I can get the rotational preload with an impact gun but to use a torque wrench i think I'm gonna have to bolt in under the jeep . Which is fine. What did you mean ?
agear is offline
post #14 of 30 Old 06-26-2021, 08:46 PM
80cj
80cj's Avatar
1980 CJ5
I thought you meant you can't get any preload reading. Did you try holding the yoke with a pipe wrench? Sometimes you need to use a pipe on the handle of the pipe wrench for more leverage to keep it from rotating as you apply torque to the nut.
80cj is offline
post #15 of 30 Old 06-27-2021, 01:09 AM Thread Starter
agear
Oh okay. Thank you . I have about a 2 1/2 ft long yoke holding tool which is just a piece of iron with 2 holes for a u bolt or strap screws to go through.
agear is offline
