Antifreeze leak. - JeepForum.com
post #1 of 11 Old 09-29-2013, 12:51 PM Thread Starter
seabass1858
seabass1858's Avatar
1983 CJ7
Antifreeze leak.
I have an antifreeze leak in the location shown. I do not remember taking anything off of this spot during the break down. I believe the machine shop may have removed something and forgot to return it to me when they did the head job. Does anyone know what goes here or is it just a plug of some sort.
seabass1858 is offline
post #2 of 11 Old 09-29-2013, 01:24 PM
LumpyGrits
Your water temp sending unit is in that area. Could it be leaking from there?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 11 Old 09-29-2013, 01:42 PM Thread Starter
seabass1858
1983 CJ7
My water temp sending unit is on my intake
post #4 of 11 Old 09-29-2013, 01:46 PM
LumpyGrits
Have you re-torqued the head bolts yet?
If not. Do so, ASAP. Coolant could be creep'n out that way too.
LG
post #5 of 11 Old 09-29-2013, 02:29 PM Thread Starter
seabass1858
1983 CJ7
i was just informed that there are 2 coolant temp sensor locations. 1 on the intake for the computer and one on the block for the temp gauge
post #6 of 11 Old 09-29-2013, 02:47 PM
Patter
Patter's Avatar
1981 CJ5
I've got a sender in that location.
For what it's worth?
"I have a very strict gun control policy: if there's a gun around, I want to be in control of it."
Patter is offline
post #7 of 11 Old 09-29-2013, 03:02 PM Thread Starter
seabass1858
1983 CJ7
yep thank you for the reference
post #8 of 11 Old 09-29-2013, 03:08 PM
82JeepCJ7
1982 CJ7
That is where the stock temp sender should be. If your not using that location, the threads are pipe thread.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #9 of 11 Old 09-29-2013, 03:09 PM Thread Starter
seabass1858
1983 CJ7
I will use it. I found the un plugged purple wire wrapped in my harness. oops shouldnt have drank too much and mess with my jeep.
post #10 of 11 Old 09-29-2013, 03:10 PM
Patter
Patter's Avatar
1981 CJ5
1/8-27 pipe.
Patter is offline
post #11 of 11 Old 09-29-2013, 06:55 PM
LumpyGrits
YUP, on the temp sensor in the head, that and RE-TORQUE the HB's!
LG
