Another ignition electrical question - JeepForum.com
post #1 of 5 Old 04-09-2020, 07:44 AM Thread Starter
PhillyCJ7
I am trying to get my CJ project back together and have another electrical question. The ignition module has two plugs coming out of it. One has a handful of wires coming out of it and they are all accounted for. The other has two wires a red and a white. On the other side of the plug there are a few wires and one is unaccounted for and just lose. Thinking it might be a ground but wondering if someone out there had a wiring diagram or could look under the hood of your truck and see is there is a ground coming out of this plug. See pic. The wire I am talking about is the one pointing up to the left. I stripped the end. I took decent pics when i disassembled and it was just hanging there before and the truck ran but I would like to clean up the wiring where I can.
Thanks in advance for your time.
PhillyCJ7 is offline
post #2 of 5 Old 04-09-2020, 08:12 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
It would help to know what you are working on. Take a moment and fill out your profile.
Matt
Matt1981CJ7 is offline
post #3 of 5 Old 04-09-2020, 08:38 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I see you have a ballast resistor with a bunch of wires hooked up at one end I would wire it up this way:
I'm a little worried about all those wires on one end of your ballast resistor though.
Normally a Ballast resistor is not used but a resistance wire is used. Don't use both. Check the voltage on the + of the coil when you are done.
Also If you have an OEM tach, it's wired a little different.
It's also different if you are still using a computer.
So like Matt says, tell us what you got...
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #4 of 5 Old 04-09-2020, 09:03 AM Thread Starter
PhillyCJ7
Thanks guys - profile updated but generally speaking, it is a 1984 / 1980 / 1979 FrankenJeep. Pretty sure there is no computer involved here. How would one tell?
John - happen to have a link or a larger picture of that second diagram?
post #5 of 5 Old 04-09-2020, 09:21 AM
Matt1981CJ7
1981 CJ7
If the distributor wires connect directly to the ICM, you don't have a computer.
Matt
