Amc v8 rough idle/wont idle down - JeepForum.com
post #1 of 2 Old Today, 09:54 AM Thread Starter
Haggenator
Just got my rebuilt amc 360 fired up for the first time. Engine will not idle down. Lowest it will idle is about 1500 rpm. Only possible vacuum leak I found is through the carburetor throttle valve shaft. Is it possible the intake manifold gasket is leaking inside the block? The metal valley pan seemed sketchy at best. This has a old Holley intake on it. The motor revs up fine. Everything to me points to vacuum leak. Anything else to look for?
1982 Jeep CJ7
AMC 258/T5/Dana 300
Dana 44/Dana 30/3.73
Haggenator is online now
post #2 of 2 Old Today, 10:10 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
What carb?
Is the choke operating correctly?
Matt
Matt1981CJ7 is online now
Impossible to solve rough idle JohnC7 ZJ Grand Cherokee Forum 32 02-23-2019 01:10 AM
High Oil Pressure and Rough Idle Zyurazek YJ Wrangler Technical Forum 28 10-10-2018 08:17 PM
Rough idle rough driving boging down and dieing Jasoncarr Internal Parts 0 09-14-2018 07:22 PM
Rough idle rough running rough driving Jasoncarr WJ Grand Cherokee Forum 1 09-14-2018 03:41 PM
'95 Cherokee 2.5L Misfire and Rough Idle Kelleys7 XJ Cherokee Technical Forum 0 05-15-2018 12:11 PM
